Gen II Beet Exhaust Question??? - Kawasaki ZX-10R.net
post #1 of 11 Old 03-13-2008, 08:56 PM Thread Starter
Ronnie@South Seas's Avatar
I am going to install my exhaust tonight and was wondering what map to use on my power commander just till I get a custom tune.... Thanks for the help.
[email protected] Seas is offline
post #2 of 11 Old 03-14-2008, 12:22 AM
Dragone's Avatar
Images: 11
Not sure, the exhaust and pc3 the only things done to the ride?
Dragone is offline
post #3 of 11 Old 03-14-2008, 12:45 AM
La Flama Blanca
9R to 10R's Avatar
Images: 102
I have been using an EVO map on mine that I fidled with a little, mostly leaning it down a bit across the board, bike runs well, It starts a little harder the first start of the day, but runs pretty good, till I can get a custom tune done someday. Probably going to swtch to the Bazaaz system, when it comes on line for the 10R
9R to 10R is offline
post #4 of 11 Old 03-14-2008, 01:12 AM Thread Starter
and K&N thats all. While I was working I thought I would removed the sec. butterflies
post #5 of 11 Old 03-14-2008, 01:14 AM Thread Starter
RIght on, I will just try the evo map.
post #6 of 11 Old 03-16-2008, 12:20 PM Thread Starter
I was able to get off work long enough to get the exhaust on. It looks great, the power comes on so much smoother but I have one problem. The bike gets extermely hot when ever I stop. The temp. shoots to 240+ I have to kill the engine or don't stop moving. So, what you guys think the problem could be???? Thanks for the help.
post #7 of 11 Old 03-16-2008, 12:24 PM
Running lean?
DareDevil is offline
post #8 of 11 Old 03-16-2008, 01:13 PM Thread Starter
I called PCIII tech line and asked them what map I should run and they recomended map 222-007 the leo vince full system. Aren't the maps they program a little rich??
post #9 of 11 Old 03-16-2008, 02:51 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Yes they are all a little rich, all the full system generic maps are pretty similar as well. Try a few of them and see which one runs the best, optimal would be get your bike on a dyno quick and see what your A/F looks like, I have not experienced any noticable increse in overheating, but I am at dead sea level, super hot summers though, heat indexes in the 110's. Its a long shto but check for obvious exhaust leaks, if they are big enough they could cause a overheating issue.
post #10 of 11 Old 03-17-2008, 02:46 AM Thread Starter
Thanks for the help but I found out the problem. I am I did not know about burping my cooling system. So, I properly filled and burped it and all was well. I would post up pics but it is nothing you haven't seen before. Thanks again.
Beet Nassert Exhaust ??? WRECKSHOP Performance and Tech 39 01-03-2010 02:15 PM
Got My BEET Nassert R Exhaust In, Teaser Pics! 9R to 10R Pictures and Videos 60 04-09-2007 12:18 PM
Beet Nassert Exhaust System kneedragger_13 The ZX-10R 32 02-02-2007 11:10 AM
beet-nassert exhaust bradshow01 Vendor Deals 2 06-05-2006 06:09 PM
Anybody know an importer of the BEET Nssert-R exhaust evander The ZX-10R 10 12-24-2005 02:16 AM
