gen four electronics issues - Kawasaki ZX-10R.net
post #1 of 6 Old 12-24-2014, 05:31 AM Thread Starter
Gum
Gday. I have crashed my gen 4. Rebuilt it with a race loom and ecu. Starts and runs well. But the traction control 123 / off is flashing and I can't adjust it also the power setting is stuck on 1 and that won't adjust as well. Any thoughts on where to look first.
Thanks Lyndon
Gum is offline
post #2 of 6 Old 12-24-2014, 06:53 AM Thread Starter
Gum
Code 62. Clearly I have done something wrong. Will have a look in the morning.
Gum is offline
post #3 of 6 Old 12-24-2014, 06:56 AM
dricked's Avatar
Check the left bar switch with a multi meter. I had the same symptoms when I wired my stm switch incorrectly. I didn't check for codes though...
dricked is offline
post #4 of 6 Old 12-24-2014, 08:14 AM
ZX-10R enthusiast
dudewhrsmybike's Avatar
Code 62 is Subthrottle valve actuator...perhaps you forgot to plug it in
Do you have a svc manual?
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #5 of 6 Old 12-24-2014, 08:19 AM
ZX-10R enthusiast
It's this plug, might want to have a look Click image for larger version
post #6 of 6 Old 12-25-2014, 01:12 AM Thread Starter
Gum
Yep. Didn't plug it in. Power and traction control all good now. Now can I make the mph cluster to read in metric.
Gum is offline
Gen 2 motor with Gen 3 electronics? Quantrill Performance and Tech 6 10-29-2013 08:40 AM
GEN 2: issues with Woodcraft case covers. Compatibility with GEN 3??? Please, HELP!!! mishanja Performance and Tech 4 04-10-2013 12:43 PM
TV electronics gurus logmaster The Out House 14 11-07-2011 11:58 PM
Need Electronics Help...Relays casey The Out House 8 08-22-2007 06:07 PM
