Gen 6 Ti Rods in Gen 1? - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By Carlos76
  • 1 Post By SpazOnaZX
post #1 of 6 Old 10-17-2018, 11:11 AM Thread Starter
I think I have read the gen 4 Rods have been used in a gen 1, now with the gen6 having Ti Rods does anyone have any info on the specs or if they are compatible and if not can they be modified to fit a gen1
GreenKawicepticon is online now
post #2 of 6 Old 10-17-2018, 02:03 PM
EvokedPotential's Avatar
or how much they weigh.....
EvokedPotential is offline
post #3 of 6 Old 10-17-2018, 02:46 PM
Carlos76's Avatar
Price spec: your bike value multiplied by two!
Boxtradamus likes this.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #4 of 6 Old 10-18-2018, 09:20 AM
SpazOnaZX's Avatar
Look at the factory service manual: it will call out pin diameter for the piston, center-to-center length, and rod bearing diameter(s).... if they are all the same compared to the gen 1, then you should be able to swap them. However, you'll have to use bearings from gen 6 as well, so make sure those also spec to the same thickness (it's in the manual as well).
For example, I'm putting rods in an 07 motor; 04-10 rods are all interchangeable. 11-14 rods will work too, but the tangs on the bearings are offset differently, so I have to run the 11+ rod bearing to make it work.
michael4012 likes this.
SpazOnaZX is offline
post #5 of 6 Old 10-18-2018, 02:57 PM
if Crowers are always $2500....
post #6 of 6 Old 10-19-2018, 11:17 AM Thread Starter
Thanks Spaz that’s what I figured , I gotta find the manual now
WTB: Gen 2 carrillo or crower rods Quantrill Wanted: Buy or Trade 2 01-31-2014 09:13 PM
2nd gen oil pan, 3 rods,and 3 pistons stretched10R Parts, Gear and Accessories 6 01-13-2014 01:36 PM
Gen 3: Gen 3 rods KIRK_ADAMS Parts, Gear and Accessories 0 10-29-2013 06:57 PM
WTB Gen 3 rods + Pistons. 880turbo Wanted: Buy or Trade 2 10-02-2013 07:44 AM
Will 3rd gen rods work in 2nd gen Bmore-stunter Performance and Tech 3 03-29-2012 10:41 PM
