Gen 5 fault code 49? - Kawasaki ZX-10R.net
post #1 of 1 Old 08-25-2019, 01:00 AM Thread Starter
Has anyone seen fault code 49? And do you know what that is? I had the flashing dash and check engine and warning light on. Its a 2018 zx10r. Not sure what I did. I did the thing where you start the engine hit select till the odometer is displayed then hold the lap timer and start stop switch to the inside, it came up with code 49? I canít find that code anywhere, its not in the service manual. I was able to clear it using the drive it for 10 minute and repeat three times pain in the a$$ thing. Seems fine now, I was just wondering if anyone has seen that code.
Mo Lasses is offline
