Gen 4 ZX10R cranks, starts briefly then dies - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By michael4012
post #1 of 9 Old 10-18-2018, 02:07 PM Thread Starter
Hi all,
Have an interesting problem with my Gen 4 (2012) ZX10R, would appreciate any help ..
Bike has Austin racing exhaust, K&N, Bazzaz mapper, Bazzaz automapper (AFM) & Bazzaz quickshift.
It was running fine at the track, then suddenly died - as if it had run out of fuel, or hit the kill switch. Now it cranks without an issue, starts briefly (maybe 0.5 sec) then dies straight away.
Diagnosis so far;
- made sure it actually has fuel in the tank (!!)
- remove each of the Bazzaz modules in turn to see if theyíve caused the issue. All 3 are now extracated from the system & the bike is using the original ECU maps.
- checked battery power & available current
None of the above have made any difference to the symptoms - still cranks fine, starts very briefly, then dies.
Any ideas out there ??? Seems a very strange problem to me ..
Thank u in advance ..
Stew
StewyO is offline
post #2 of 9 Old 10-18-2018, 02:18 PM
ddipaola's Avatar
Did your tip-sensor go bad? Also does it stall in neutral? or only when in gear?
When in doubt... send it!
ddipaola is offline
post #3 of 9 Old 10-19-2018, 11:47 PM Thread Starter
It stops whether in neutral or in gear, Iíve tried both scenarios with & without the clutch pulled in.
Iím pretty sure itís not the tip sensor, Iíve had 1 fail in the past & if the circuit isnít complete it doesnít let the bike fire. Iíll double check it though.
StewyO is offline
post #4 of 9 Old 10-20-2018, 01:33 AM
michael4012's Avatar
Interesting, i suspect a fuel pump issue, when it dies will it start again for another 1/2 sec without turning the ignition off & on or does it require turning off & on so that the fuel pump re primes, do you hear the pump priming when you turn the ignition on?
badassjake likes this.
michael4012 is offline
post #5 of 9 Old 10-20-2018, 10:37 AM Thread Starter
Yes it will start again (briefly !!) without recycling the ignition. On the first switch on, I can hear the fuel pump priming normally ..
Itís a head scratcher !!!
StewyO is offline
post #6 of 9 Old 10-20-2018, 01:15 PM
F 18 driver's Avatar
hi StewyO,
When you ran out of fuel. You got all the debris from the tank clogging the micro filters in the fuel injectors.
Let us know how it turns out
F-18 driver
F 18 driver is offline
post #7 of 9 Old 10-21-2018, 01:44 AM Thread Starter
Only thing is, it never actually ran out of fuel - itís the best way I could describe how it stopped ..itís worth having a look at the injectors to eliminate the possibility though ..
The diagnosis continues ..would appreciate any wise words / ideas from anyone out there ..
StewyO is offline
post #8 of 9 Old 10-21-2018, 03:31 AM
badassjake's Avatar
pull the pump...see what condition it is in.
badassjake is offline
post #9 of 9 Old 10-24-2018, 07:51 PM Thread Starter
Will have a look & let you know ..
StewyO is offline
Gen 4: bike cranks, then battery starts to go dead tyto17 The ZX-10R 7 08-26-2017 06:14 PM
Gen 1: Starts, Dies, & Then Doesn't Start SovietGSXR1000 The ZX-10R 4 11-17-2013 04:22 PM
Clutch slipping briefly after gear change? Alcatrax Performance and Tech 1 05-01-2011 06:08 AM
bike starts and dies immediatley stuntha1k Performance and Tech 7 10-13-2010 08:45 PM
06 engine dies, cycle the key and starts again dscort Performance and Tech 8 05-25-2010 06:55 PM
