Gen 4 rods - Kawasaki ZX-10R.net
post #1 of 6 Old 08-29-2014, 06:32 AM Thread Starter
Gen 4 rods
Anyone know if Gen 4 rods will fit in a Gen 2/3 motor?
Quantrill is offline
post #2 of 6 Old 08-29-2014, 07:08 AM
gazx10's Avatar
not for sure, but doubt it. gen 4 has rod/crank centerline offset 2mm to reduce loading on ex. side reducing friction.
gazx10 is offline
post #3 of 6 Old 08-29-2014, 08:40 AM Thread Starter
I found this while researching the 2mm offset.
Also, while the pistons have minimal pin offset for nominal drag, the cylinder block has been machined with 2mm of frontward axis, this offset measured forward from the centerline of the crankshaft's con rods. Adopting this offset greatly reduces thrust loading on the pistons, with Kawasaki's reduction numbers being quite telling: 18% less at 5,000rpm, 21% at 10,000, and 9% less at 13,000.
If it is 2mm forward of the center line of the crank how would this effect compatibility?
Thanks
post #4 of 6 Old 08-29-2014, 10:23 AM
gazx10's Avatar
depends on if and how kaw compensated rod length for wristpin and rod journal offset. if rods are same length, moving them 2mm back to preious gen centerline would affect deck height to a point not workable. with altered crank, altered wristpin location, different pistons, and gen 4 head deck at different angle, i would forsee some problems making it work. just a opinion and pure benchracing. if looking for stronger budget rod, shot peening and heat treating good option often overlooked.
gazx10 is offline
post #5 of 6 Old 08-30-2014, 11:30 AM Thread Starter
Anyone else have some input on this subject? Gen 4 rods would be a great substitute for the more expense H Beam rods if they are compatible??
post #6 of 6 Old 08-30-2014, 02:26 PM
badassjake's Avatar
ebay 1 rod and measure it up. questions will be answered.
badassjake is offline
WTB: Gen 2 carrillo or crower rods Quantrill Wanted: Buy or Trade 2 01-31-2014 09:13 PM
2nd gen oil pan, 3 rods,and 3 pistons stretched10R Parts, Gear and Accessories 6 01-13-2014 01:36 PM
Gen 3: Gen 3 rods KIRK_ADAMS Parts, Gear and Accessories 0 10-29-2013 06:57 PM
WTB Gen 3 rods + Pistons. 880turbo Wanted: Buy or Trade 2 10-02-2013 07:44 AM
Will 3rd gen rods work in 2nd gen Bmore-stunter Performance and Tech 3 03-29-2012 10:41 PM
