gen 4 oil pump leak - Kawasaki ZX-10R.net
post #1 of 14 Old 03-01-2015, 02:10 PM Thread Starter
gen 4 oil pump leak
Any one have picture of which way oil seal should face in oil/water pump housing? Dealer may have installed upside down and no way to verify..normally the back of the seal would face fluid but this was opposite.. Service manual has no pictures of seal installed
cnrjames is offline
post #2 of 14 Old 03-01-2015, 02:18 PM
slothman's Avatar
take it back and make them fix it correctly .
slothman is offline
post #3 of 14 Old 03-01-2015, 02:19 PM Thread Starter
flash ecU and installed block off plates, slip on, stupid dealer probably argue with me about it being under warranty anymore
cnrjames is offline
post #4 of 14 Old 03-01-2015, 02:22 PM Thread Starter
plus the quality job the dealer did on the install, they scratched the housing all up removing the old seal because he doesn't know how to use his tools..of course gouges are not where the oil leak is coming from sadly..
cnrjames is offline
post #5 of 14 Old 03-01-2015, 03:47 PM
regardless they should fix it.
shortbusondubs is offline
post #6 of 14 Old 03-01-2015, 06:42 PM Thread Starter
they did crappy work and I don't want to take it back, has anyone had one of these oil pumps apart?
cnrjames is offline
post #7 of 14 Old 03-01-2015, 08:35 PM
SkyDork's Avatar
No, but I looked in the manual and not sure what seal you're referring to. The oil pump itself didn't have a seal. The outer housing just uses an oring. You just put the oring in the groove and lube it up. There is no direction for it.
#WordCrimes
SkyDork is offline
post #8 of 14 Old 03-01-2015, 09:28 PM Thread Starter
Maybe there is a member who has rebuilt the gen 4? I appreciate your help..
cnrjames is offline
post #9 of 14 Old 03-02-2015, 03:39 AM
There's an oil seal under the two piece water pump mechanical seal.
As to which way it should be, probably as the OP said, open side to oil pump
Bigunz is offline
post #10 of 14 Old 03-02-2015, 09:01 AM
SkyDork's Avatar
I was PMing with cnrjames about this last night. I see now what he's referring to and agree with what you say too. Open end towards the oil pump. But again, I have no first hand experience with this.
#WordCrimes
SkyDork is offline
2004 ZX10R Water Pump/Oil Pump leak notjeep The ZX-10R 4 09-17-2013 11:07 PM
Gen 4 oil leak scottishsg Performance and Tech 40 02-13-2013 11:52 PM
Gen 2 Oil Leak, please help! phasterthanyou Performance and Tech 23 04-06-2012 03:21 PM
gen 2 oil leak ? gldnchildek9 The ZX-10R 13 04-21-2009 06:59 PM
tech help please water pump leak oil b/s gsxr 600 The ZX-10R 0 09-19-2007 08:39 PM
