Gen 4 Idle Problems - Kawasaki ZX-10R.net
post #1 of 10 Old 05-26-2013, 12:41 PM Thread Starter
kawboy69's Avatar
Gen 4 Idle Problems
I am having problems with my Gen 4 ideling a little high. When I clutch to stop it idles up 2k the. After 10 to 15 seconds it i does down. It's also will not crank if it is in gear even with the clutch pulled in and the kick stand up.
Does anyone have any ideas what could be causing this. A few months ago my bike brought up error code 39 but I charged the battery and it never came back on.
It's better to shut up and appear stupid than open your mouth and remove all doubt.
kawboy69 is offline
post #2 of 10 Old 05-26-2013, 01:24 PM
SkyDork's Avatar
Maybe a vacuum leak or something similar. What mods you got? The G4 idle is controlled by the computer, so there's no manual adjustment. Sounds like a sensor is going flaky or something.
#WordCrimes
SkyDork is offline
post #3 of 10 Old 05-26-2013, 01:32 PM Thread Starter
kawboy69's Avatar
Guhl reflash, slip on PCV, SFM with QS BMC filter could the firmware on my PC cause that? Thanks SkyDork
kawboy69 is offline
post #4 of 10 Old 05-26-2013, 02:13 PM
SkyDork's Avatar
I'd say yes if you just installed the PCV and this issue showed up. Bit if you've been running this setup for awhile, I doubt that's the issue. But what firmware are you running? I think there was an issue prior to 1.9.0.
#WordCrimes
SkyDork is offline
post #5 of 10 Old 05-26-2013, 02:43 PM Thread Starter
kawboy69's Avatar
I am running 1.8.5 firmware. I will have to change to the 1.9.0 and see if that corrects the issue, but that doesnt explain the starting problem while in gear with the clutch pulled.
kawboy69 is offline
post #6 of 10 Old 05-26-2013, 05:04 PM
The Pace
scout's Avatar
That idle is what mine does, exactly. Doesn't bother me at all, but I do notice it. That start prob is serious, to me. One of the stupid switches, either kick or if you changed out the clutch lever. Someone here knows, but that would bother me so much I'd take it to a tech and let him sort it out if no one come up with a quick solution here.
scout is offline
post #7 of 10 Old 05-26-2013, 05:27 PM
jdub669's Avatar
Its the safety switch on your clutch lever.
If it was the kickstand switch you wouldn't be able to start in neutral and shift into gear. It would die as soon as you shift.
"mechanical engineers build weapons, civil engineers build targets"
jdub669 is offline
post #8 of 10 Old 05-26-2013, 05:50 PM
Evil10's Avatar
do you have stock levers ?
Evil10 is offline
post #9 of 10 Old 05-26-2013, 08:14 PM Thread Starter
kawboy69's Avatar
Yes my levers are stock. I do not hear the switch when I squeeze the clutch.
kawboy69 is offline
post #10 of 10 Old 05-26-2013, 10:36 PM Thread Starter
kawboy69's Avatar
Ok. Starting issue solved. I unplugged the safety switch and played with it and it works.
I also updated firmware to 1.9.2 I will see if that fixs the high idle problem tomorrow
Thanks for the help..!
kawboy69 is offline
2006 zx10r idle problems 2xtreme10r Welcome Newbies! 16 05-12-2014 08:52 PM
Gen:4 how do you adjust idle???? 2012zx10r Performance and Tech 12 01-05-2013 07:00 PM
Gen 4 idle issue OKC ZX-10R Performance and Tech 6 05-09-2012 09:34 PM
"idle problems" appocalypse Performance and Tech 5 06-15-2009 05:17 PM
idle problems fbdr24 The ZX-10R 3 11-21-2004 09:03 AM
