Gen 3 wheels on Gen 4- how to? - Kawasaki ZX-10R.net
post #1 of 10 Old 03-25-2013, 10:26 AM Thread Starter
GODSPEED's Avatar
Ok so to start, YES I have researched the threads to do this swap and to be honest still kind of confused, and I am ordering parts today.
I want to go the route without drilling anything.
I have a Gen 3 rear wheel.
Apparently the "Garth" way is the easiest but still dont know what I have to do.
I have a bare rim, so as I understand it do I:
1 - order OEM Gen 3 bearings
2 - Order a 2011 inner spacer (the long one)
3 - Make a spacer to go inside the rear caliper mount- same width/size as the caliper to fit on the Gen 3 axel?
Thanks for clearing anything up for me.
GODSPEED is offline
post #2 of 10 Old 03-26-2013, 01:15 AM Thread Starter
GODSPEED's Avatar
k, Gen 3 rear wheel for sale. I will just buy a gen 4 then. 199 shipped.
GODSPEED is offline
post #3 of 10 Old 03-26-2013, 07:39 PM
Speed Freak
garth285's Avatar
On my bike I ran the gen 1-3 rear axle and adjuster blocks and she bolted right up. I also had to make a spacer that sized down the hole that the rear brake caliper has I think (Just going from memory) that it needs to be brough down from 20mm to 17mm ... I think...
use the gen 1-3 spacers.
fronts will just bolt right up.
garth285 is offline
post #4 of 10 Old 03-27-2013, 09:43 PM
Haga46's Avatar
The spacer i made for the G3 wheel was 18,5mm, did go a different way but the spacer is the same in lenght
Haga46 is offline
post #5 of 10 Old 03-27-2013, 10:25 PM Thread Starter
GODSPEED's Avatar
So do you guys mean- 1 spacer for the caliper mount- somewhere between 17 and 20mm in length, 20 mm ID and 25mm OD? just mic out the caliper mount width around the axel and good to go?
GODSPEED is offline
post #6 of 10 Old 03-28-2013, 09:51 PM
Haga46's Avatar
This is my drawing but it's for the G4 axel witch is thicker then the G3 axel maybe Garth285 can measure or post a drawing of his for the G3 axel ?
Name:	Wielbus voor ZX-10R 2011[1].JPG
Haga46 is offline
post #7 of 10 Old 03-28-2013, 10:36 PM
Always On Mod
Animal11's Avatar
I have a Gen 1 rear wheel mounted on my gen 4. I used the wheel, axle, bearings spacers from the gen 1. It all bolts up clean. I used the caliper mount from the gen 4 cause it has the TC sensor mount built in. Without a spacer the caliper mount isn't a perfect fit for the gen 1 axle, but it also won't crash. I ran this setup at the track yesterday with no issues. I can upload a drawing for the caliper spacer tomorrow if you'd like.
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #8 of 10 Old 03-30-2013, 07:24 PM Thread Starter
GODSPEED's Avatar
Ok.... So definitively its direct bolt, and the only hardship is the spacing (ID / OD from Axel size to Caliper mount size on why people are adding a spacer.
For your post tho, you say you have no spacer, and just rock the caliper as is with a little bit of room(approx 5 mil) between the two, yet you do have a spacer?
GODSPEED is offline
post #9 of 10 Old 03-30-2013, 08:01 PM
Always On Mod
Animal11's Avatar
I plan to run with a spacer for long term, but didn't get one made yet. The caliper bracket is a loose fit to the axle anyway, so the 2.5mm it can move isn't the end of the world. And, without the space it won't crash the caliper into the rotor. I may just be lazy and not put a spacer in, we'll see.
Animal11 is offline
post #10 of 10 Old 06-08-2015, 05:44 PM
Crescent1101's Avatar
Anybody know where I can get a spacer for the rear caliper bracket?
Crescent1101 is offline
Wanted- 10R Parts - GEN 4 (and GEN 3 Wheels)s GODSPEED Wanted: Buy or Trade 15 08-26-2013 03:18 AM
Gen 4: Will stock gen 3 wheels fit gen 4? Killa Kawi The ZX-10R 1 12-07-2012 07:51 AM
Anyone know if gen 4 wheels will fit on 2nd gen? caz345 The ZX-10R 7 11-18-2011 10:10 AM
GEN 1 BST WHEELS fit GEN 3? ILOAD2 Performance and Tech 2 07-01-2009 10:30 PM
Do 1st Gen and 2nd Gen wheels swap? Sonic 10R Performance and Tech 5 08-13-2006 10:05 PM
