Gen 3 upper injector earlier feed - Kawasaki ZX-10R.net
post #1 of 5 Old 04-29-2015, 10:54 PM Thread Starter
Anyone know if there is any benefit in HP to feeding the upper injectors earlier in TP / RPM range?
Anderson is offline
post #2 of 5 Old 04-29-2015, 11:09 PM
SkyDork's Avatar
Injector balancing was discussed somewhat in the epic a Woolich thread. If I remember correctly, there wasn't much if any gains to be had by shifting it downwards.
#WordCrimes
SkyDork is offline
post #3 of 5 Old 04-30-2015, 07:49 AM Thread Starter
OK, Thanks.... If you find that thread can you post a link to it?
Anderson is offline
post #4 of 5 Old 04-30-2015, 10:12 AM
SkyDork's Avatar
Start reading in this area:
https://www.zx-10r.net/forum/f23/new-...142537-13.html
#WordCrimes
SkyDork is offline
post #5 of 5 Old 05-02-2015, 01:16 PM Thread Starter
Thank YOU!!
Anderson is offline
Gen 4: Bsd ecu flash using Woolich mention upper lower injector balance change abadassbikerlad The ZX-10R 30 10-10-2019 12:05 PM
Gen 4: Gen 4 Fuel Injector Part number/flow garth285 Performance and Tech 3 03-02-2015 05:39 PM
gen 4 injector ? kawboy619 The ZX-10R 11 08-05-2014 01:37 AM
Gen 4 lower fuel injector flow rate? Quantrill Performance and Tech 1 12-15-2013 10:10 AM
3rd gen fuel injector question KIRK_ADAMS Performance and Tech 6 12-31-2010 02:18 PM
