Gen 3 Speedo erratic - Kawasaki ZX-10R.net
post #1 of 4 Old 04-25-2011, 03:34 PM Thread Starter
fastburnzx-10's Avatar
Send a message via AIM to fastburnzx-10 Send a message via MSN to fastburnzx-10
Have a 08 zx10 got it from older guy and the speedo isnt registering. correct speed.. He told me that it wasnt the speedo healer but was wondering if anyone else has had this issue?
fastburnzx-10 is offline
post #2 of 4 Old 04-25-2011, 04:53 PM
SkyDork's Avatar
If you've already ruled out the Speedo Healer, then it's only 1 of 3 things: speed sensor, ECU, or instrument cluster. Cheapest and most probable culprit is the speed sensor.
#WordCrimes
SkyDork is offline
post #3 of 4 Old 04-25-2011, 05:00 PM
Late Apex
Solo-Six's Avatar
I would say its the Speed Sensor "FINAL ANSWER" . Instrument Cluster ..Its too new (Unless Your Dropping Wheelies from 10oClock) and the SpeedoHealer Well You ruled that out bt I would double check that ..
Just take your speed sensor off , inspect it for visual damage and iif none is apparent grab a used one off Ebay or borrow a friends to verify thats it.. there are ways to test that sensor but Im assuming your toool box doesnt contain the toools needed and reading devices as well as range its good for as far as load resistance and normal resistance... :headshake
Solo-Six is offline
post #4 of 4 Old 04-25-2011, 05:28 PM Thread Starter
sounds good man. i have a multi meter.. but i wouldnt know the specs or anything.. Thanks for the info.. Whats the best way to double check the speedo healer
Erratic Speedo Readings pls Help Larry Grogan Performance and Tech 13 08-15-2010 09:25 PM
New 10r speedo on an 05? Scott10r Performance and Tech 5 09-30-2009 12:53 PM
speedo gsredhot01rt The ZX-10R 10 12-04-2006 12:15 AM
Erratic Speedometer Older Guy The ZX-10R 8 10-24-2005 12:40 AM
speedo gabe The ZX-10R 13 09-14-2005 02:56 AM
