gen 3 spark plug removal - Kawasaki ZX-10R.net
post #1 of 7 Old 05-09-2011, 07:47 PM Thread Starter
hey guys i am haveing trouble gettting to the two spark plugs on each end of the motor. ive changed the 2 in the middle. are there any tricks to getting to these on and 09 model. help is much apreicated
jesilvers19999 is offline
post #2 of 7 Old 05-09-2011, 07:57 PM
Maddevill's Avatar
If it's like the Gen 1 you have to move the outer motor mounts out of the way. You can sometimes just remove a bolt, loosen the other and swivel it out of the way.
Maddevill is offline
post #3 of 7 Old 05-09-2011, 08:13 PM
you dont actually have to remove the mounts. what you need is a spark plug socker, a very short extension, a swivel for that extension, another a little longer extension. what i do, i just kinda build the tool as im putting it into the hole.
mityaz is offline
post #4 of 7 Old 05-09-2011, 08:19 PM Thread Starter
I'm having trouble getting the coil pack out of the hole I pull it out and it his the frame before it clears the hole
post #5 of 7 Old 05-09-2011, 08:23 PM
mrbzx7's Avatar
I dont remove mounts either, I think I had to put plug in the hole, then put socket on then extension to socket. Wouldn't go in all together ya just got to play with it a little
mrbzx7 is offline
post #6 of 7 Old 05-09-2011, 09:30 PM
ninja44's Avatar
I just did mine, took about 45 mins from start to finish. The outer coils come out toward the front of the bike, they will naturally want to slide out between the frame and engine. Once you get it half way out press LIGHTLY down on the top end of the coil and it will come right out, goes back in the same way.
Sean
08 10R Pearl Wildfire Orange
Akra slip on W/Link Pipe, Ohlins R&T Forks, Ohlins 46PRXLS, Attack Rearsets, Guhl ECU Reflash, Ivan's Block Offs, Pazzo Levers, Goodridge Carbo Brake Lines, Vesrah RJL Pads, Riflemans 1/5 Throttle Insert, R & G Sliders & Engine Guards, Puig Z Screen, Puig Hugger, Evotech 1/4 turn gas cap
ninja44 is offline
post #7 of 7 Old 05-10-2011, 07:36 AM
Gen 5 Now!!
08zx10rny's Avatar
Originally Posted by ninja44 View Post
the outer coils come out toward the front of the bike, they will naturally want to slide out between the frame and engine. Once you get it half way out press lightly down on the top end of the coil and it will come right out, goes back in the same way.
GEN 5!!!
08zx10rny is offline
Spark Plug install? tapuout567 Performance and Tech 10 06-21-2010 06:23 PM
Spark Plug Removal Upper Brackets fungames43232 The ZX-10R 6 07-11-2009 02:38 PM
Spark Plug?? blackisfaster Performance and Tech 7 08-23-2007 09:34 AM
spark plug gap eric Performance and Tech 4 04-23-2007 10:22 PM
which spark plug? livnpaintball Performance and Tech 43 12-15-2006 04:36 PM
