Gen 1: 2004-2005 Gen 3 fuel pump in my gen 1 - Kawasaki ZX-10R.net
post #1 of 5 Old 03-28-2018, 12:23 AM Thread Starter
Long story short i got the bike about 3 weeks ago. It pulled hard when i got it but suddenly it wouldnt pull above 8 grand. I tested the pump flow and it was below 40ml in a 4 second prime. Cool i order a 04 fuel pump. It arrive and im excited to feel the wrath of the widowmaker.
I get my old pump out and boom its totally different. I message the seller and he said thats a 08 pump. At some point someone installed a 08 pump and i will send you the correct 1. My question is will this work ok (semed to before)or do i need to go for a gen 1.
bigirb2002 is offline
post #2 of 5 Old 03-28-2018, 06:36 AM
gaz
gen 1-2 pump assembley housing has a sump built in it the longer fuel pump fits in. gen 3 has the shorter flat with the tank no sump assembley housing and requires the shorter pump. pumps wont interchange. u need the gen 3 smaller pump to fit up. correct gen 3 pump will work as well as gen 1 pump/housing on ur bike, so no problem. gen 1 pump requires complete gen 1 pump asembley.
gaz is online now
post #3 of 5 Old 03-28-2018, 11:38 AM Thread Starter
Thanks man i got the gen 3 pump otw
post #4 of 5 Old 03-30-2018, 01:21 AM
Kawasaki Whisperer
MrMoto73's Avatar
Send a message via MSN to MrMoto73
I am confused...... So you have a Gen 1 with a Gen 3 pump in it. You ordered a Gen 1 pump. So.....why doesn't it work in your Gen 1 and then you ordered a Gen 3 pump?
Do you have a Gen 1 tank on the bike?
I DON"T HAZ ANY SNYDER PROBLEMS
MrMoto73 is offline
post #5 of 5 Old 03-30-2018, 05:49 AM
gaz
has gen 1 tank, was unaware previous owner installed gen 3 pump assembley.
gaz is online now
Gen 5 fuel pump in Gen 4 Javadust The ZX-10R 4 01-19-2018 02:35 PM
For Sale: Gen 3 fuel pump $75 brl0301 Parts, Gear and Accessories 0 07-24-2013 07:49 PM
Gen 1,Gen 2 Fuel Pump and Head for sale NinjeR Parts, Gear and Accessories 39 05-30-2011 01:10 AM
GEN 1 and GEN 2 fuel pump compatible? 2fast2wheels The ZX-10R 0 02-13-2011 01:11 PM
3rd Gen Fuel Pump 09zx10miami Performance and Tech 1 12-01-2010 11:39 AM
