Gen 3: 2008-2010 gen 3 front sprocket quick question - Kawasaki ZX-10R.net
post #1 of 10 Old 04-10-2013, 05:18 PM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
Putting on my driven front sprocket and was wondering which side goes out. i tried to search quick but couldnt find anything. does the side with the lettering go out? thats the top in the picture or does the flat side go out?
65, pos
8.67 @ 154mph
Blue08 is offline
post #2 of 10 Old 04-10-2013, 07:14 PM
cciwchamp2's Avatar
lettering goes out i believe
cciwchamp2 is offline
post #3 of 10 Old 04-10-2013, 07:57 PM
Grease Monkey Bandit
AirborneMechanic's Avatar
Just did this on mine, just look at the one you just took off and note how each side is worn. I believe the side with with greater wear is the engine side. Then compare the sprockets and you'll be able to tell how the new one goes on.
Sent from Motorcycle.com App
"Homewrecker" Gen3 custom build by ZX-SIK-R in progress.... check the build thread: https://www.zx-10r.net/forum/f28/airb...ad-140226.html
AirborneMechanic is offline
post #4 of 10 Old 04-11-2013, 12:23 AM
Lee V's Avatar
The flat side faces out and the the pic as you show it faces in, other wise the chain will be out of alignment
Lee V is offline
post #5 of 10 Old 04-11-2013, 07:27 AM
plasticbaby's Avatar
Wrong!
plasticbaby is offline
post #6 of 10 Old 04-11-2013, 08:48 AM
wunnam's Avatar
Originally Posted by plasticbaby View Post
Wrong!
elaborate
wunnam is offline
post #7 of 10 Old 04-11-2013, 08:29 PM
BobFinnell's Avatar
Wrong!
Why?
This is from a sprocket site about Driven sprocket.
Q: How do I know how to correctly install my countershaft sprocket?
A: Always measure the distance between the sprocket itself and the motor before you attempt to
replace it. This will help you later with the correct orientation when re-installing the front sprocket.
I would put the stocker back on and see where it sits on the shaft.
08 ZX-10r Lime Green | Full Akra | BMC street filter | Bazzaz Z-Fi W/map switch, Bazzaz Z-AFM | Secondary's Removed | GPR V4K | Scorpio i-900 | Wood Craft sliders | Roadlok disklock
BobFinnell is offline
post #8 of 10 Old 04-11-2013, 09:46 PM
SkyDork's Avatar
Wrong!
^^^^ this guys gets it. He's saying Lee V is wrong. The numbers stamped on the sprocket go to the outside. It's done like that for easy verification of the sprocket. Pull the cover and you can read the sprocket size. Wouldn't do much good on the inside! Plus, the shoulder is machined to space the nut on the shaft with the washer. If you put the flat side out, the chain will be misaligned slightly.
#WordCrimes
SkyDork is offline
post #9 of 10 Old 04-11-2013, 11:12 PM
Lee V's Avatar
well thats not the case with the renthal ones, is this a 520 sprocket?
the whole point of the offset on the sprocket is to make up for the difference in width?
Lee V is offline
post #10 of 10 Old 04-12-2013, 07:00 AM
SkyDork's Avatar
It is usually the case for them to account for the difference in width, but usually so that the nut and washer will hold the sprocket on. The axis of the sprocket and chain remains the same. Especially when matching the front and rear sprockets. The chain is tolerant enough to handle a few millimeters of misalignment, but I've never seen a shouldered sprocket like that with the flat side out.
#WordCrimes
SkyDork is offline
Quick!!! Gen 2 question! 95zx9r The ZX-10R 5 03-09-2013 07:51 PM
GEN 1.....front sprocket question....... TNZX10 Performance and Tech 9 08-18-2011 09:10 AM
Quick question about sprocket cover TI10 The ZX-10R 2 10-02-2007 09:27 AM
Quick and lazy front sprocket change Katmanblues Performance and Tech 3 04-26-2007 11:11 PM
Front Sprocket Question IcePick06 Performance and Tech 18 12-17-2005 07:49 PM
