Gen 3 Crankshaft in Gen 2 motor? - Kawasaki ZX-10R.net
post #1 of 20 Old 07-17-2012, 11:10 AM Thread Starter
cMac's Avatar
Does anyone know if 08 -2010 cranks will work in an 06/07 motor. They are reportedly 2lbs lighter than the 2nd gens. I'm looking to reduce the gyroscopic effect and make the bike more flick-able. The crank cases changed but the dimensions are supposed to be the same.
Thanks for any advice
cMac is offline
post #2 of 20 Old 07-17-2012, 01:53 PM Thread Starter
cMac's Avatar
Wheres Garth when hes needed?"
cMac is offline
post #3 of 20 Old 07-17-2012, 01:59 PM
All show and all go 10r
JLG0987's Avatar
as far as I know everything in the gen 2 and 3 motor is interchangeable.
JLG0987 is offline
post #4 of 20 Old 07-18-2012, 04:01 AM
thundercoupe9's Avatar
I have a gen3 crank in my gen2 cases.
thundercoupe9 is offline
post #5 of 20 Old 07-18-2012, 07:34 AM Thread Starter
cMac's Avatar
Thanks Guys.
cMac is offline
post #6 of 20 Old 07-18-2012, 07:51 AM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
Can u wiegh the 2 cranks and report back?
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #7 of 20 Old 07-18-2012, 12:06 PM
3rd gen crank on the left, and 2nd gen on the right, you can see the difference
post #8 of 20 Old 07-18-2012, 12:34 PM
Images: 70
Damn!
Guess ill b looking for one of those
Thanks thunder
www.sportbikepc.com
post #9 of 20 Old 07-18-2012, 02:01 PM
mrbzx7's Avatar
I know the clutch baskets won't interchange so I'd say no, but I think its been answered all ready.
Andrews Motorsports
2009 ZX10R aka "The General"
2008 ZX14R coming soon!
Paypal [email protected]
mrbzx7 is offline
post #10 of 20 Old 07-18-2012, 02:18 PM Thread Starter
cMac's Avatar
http://kawasakiworld.com/zx-10r/3929...fications.html
Four-Cylinder, DOHC 998cc Engine
- Very compact, narrow and lightweight design makes it possible to position the engine perfectly within the chassis for optimal weight distribution
- One-piece upper crankcase and cylinder casting saves weight and offers maximum rigidity
- Oil is routed through channels milled into the cases on various parts of the engine, eliminating external oil lines and reducing weight
- Stacked, triangular layout of crank axis, input shaft and output shaft reduces engine length and aids mass centralization for quick handling
- Lightweight crankshaft maintains the same inertial moment as a heavier design but saves about two pounds compared to a conventional crank
- Low friction oil pump reduction ratio reduces parasitic power loss
- Water pump uses the same type impeller as the ZX-14, with pump rpm optimized for reduced friction
- A lightweight Denso radiator with tightly packed cores provides the most efficient engine cooling possible
- Specially designed internal fins on the liquid-cooled, aluminum oil cooler promote high-efficiency heat dissipation
cMac is offline
Gen 1: 04 Crankshaft TINYTURBO Parts, Gear and Accessories 9 09-04-2012 11:46 AM
Best Crankshaft Service garth285 Performance and Tech 36 01-20-2012 07:02 PM
Looking for a 07 Crankshaft Quantrill The ZX-10R 0 11-24-2010 03:30 PM
WTB: 04/05 Crankshaft clutch master Wanted: Buy or Trade 1 12-20-2009 06:23 PM
crankshaft splatmaster ZX11 Discussion 6 03-16-2006 10:09 PM
