gen 3 chain and sprocket help - Kawasaki ZX-10R.net
 2Likes
post #1 of 15 Old 04-05-2015, 02:43 PM Thread Starter
Nick13's Avatar
i just past from a dyno tune on a dyna pro dyno. i did 187.02 bhp on a stock engine but the chain was actually playing left and right on the dyno so we didnt push the bike for more.ill attach a photo of it, but i would like to ask what kind of chain and what gearing do you guys sugest the bike is gen3 zx10r. A lot will be saying its too much for a stock engine without cams and other mods, i have seen higher results on other dynos 5-6 hp, and once lower by 2hp in the past.
Nick13 is offline
post #2 of 15 Old 04-05-2015, 02:48 PM
JUICEBOX's Avatar
I just went -1 front on my Gen 3 and it made all the difference in the world.
JUICEBOX is offline
post #3 of 15 Old 04-05-2015, 02:53 PM
michael4012's Avatar
if your getting a new chain then really you should replace the sprockets as well if your doing that i recommend you go down to a 520 pitch it realise a little more power because there is a little less resistance also getting a aluminium hardened sprocket on the rear also releases a little more power because there is slightly less weight as long as you get a good quality hard chain i promise you wont regret it.
michael4012 is offline
post #4 of 15 Old 04-05-2015, 02:55 PM Thread Starter
Nick13's Avatar
that shows final speed drop about 20km
is it aluminum sprockets that you used or steel ? and what size chain 520 or 525 ?
Nick13 is offline
post #5 of 15 Old 04-05-2015, 02:56 PM
Crash Test Dummy
Hernando's Avatar
Send a message via Yahoo to Hernando Send a message via Skype™ to Hernando
Those results look good nick. The optimal gearing will depend on your intentions.
I personally have a box of aluminum sprockets and use a 520 pitch. -1 +2 seems to work very well. On the longer tracks I'll use -1 or -1 +1. Good luck.
Hernando is offline
post #6 of 15 Old 04-05-2015, 03:00 PM Thread Starter
Nick13's Avatar
ok guys then i ll do the 520 chain. now the sprockets i ll see the combinations you guys suggest.
Nick13 is offline
post #7 of 15 Old 04-05-2015, 03:08 PM Thread Starter
Nick13's Avatar
Any particular brand of sprockets and chain ? i think i ll go for tsubaki chain do you suggest anything better ?
Nick13 is offline
post #8 of 15 Old 04-05-2015, 03:23 PM
Crash Test Dummy
Hernando's Avatar
I use the DID erv3 chains.
Hernando is offline
post #9 of 15 Old 04-05-2015, 03:52 PM
caboose's Avatar
Send a message via MSN to caboose
I have use the DID erv3 chains.
This and only this.
caboose is offline
post #10 of 15 Old 04-05-2015, 09:39 PM
R/T Performance's Avatar
Just put a EK 520 chain on mine and went with steel sprockets -1 +3 I decide to get Driven sprockets from Mary @superbike supply they also have some lighter weight drive systems sprockets that will way out last any aluminum sprocket definitely don't get vortex there junk just look at the 100 of them at wheelers by deals gap
R/T Performance is offline
Gen 4 chain and sprocket suggestions. Knarf Performance and Tech 15 01-21-2015 10:37 PM
Gen 1 chain and sprocket advice sought rapid van cleef The ZX-10R 22 04-17-2014 07:35 PM
zx10 arm 64-66" w/chain gaurd/air, ekzzz chain, and sprocket..all $550 tyd ke2012 Parts, Gear and Accessories 14 07-04-2012 08:57 AM
04-05, 1st gen FRONT/REAR SPROCKET & 525 CHAIN. VORTEX(15T/42T) BRAND NEW!! ke2012 Wanted: Buy or Trade 3 07-28-2010 02:11 PM
OEM 2006-07 ZX10R Chain,front sprocket,rear sprocket, and Pirelli Dragon front tire Killerzxrider Parts, Gear and Accessories 0 09-26-2008 06:25 PM
