Gen 2 regulator and or stator - Kawasaki ZX-10R.net
post #1 of 7 Old 05-26-2015, 07:41 PM Thread Starter
So riding the other day and mid ride sitting at a light I lost power to my tach. Bike was still running then it died shortly after. Dead battery so why, it's brand new. Did some reading about issues with the gen2 charging system. I got the regulator out and will test it then the stator. If they are dinked would it be wise to go oem or I've seen these ricks racing components for about 2 bills a piece. Any input is appreciated. Thanks
Dutch is offline
post #2 of 7 Old 05-26-2015, 08:45 PM
Well if you do go stator, I know Rick's makes quality products. Ive used a couple on different bikes without problem.
Zew2888 is offline
post #3 of 7 Old 05-26-2015, 08:52 PM
SkyDork's Avatar
Oem
#WordCrimes
SkyDork is offline
post #4 of 7 Old 05-27-2015, 05:34 AM
or10r's Avatar
Member Pigman is going through the same issues.
or10r is offline
post #5 of 7 Old 05-27-2015, 02:39 PM
PigMan's Avatar
Yup.. ,, Go here for some great info
..https://www.zx-10r.net/forum/f28/gen-...ms-273017.html
Let me know how you make out with the issue if you would please.
Thanks
PigMan is offline
post #6 of 7 Old 05-28-2015, 12:14 AM Thread Starter
So a buddy helped me out with testing the regulator and 4 phases were reading 400k ohms when the limit according to the service manual states they should be between 20k and 200k of resistance. So in short my regulator is done. Will now test the stator to determine if it is OK and whether or not it was the cause the regulator failure.
Dutch is offline
post #7 of 7 Old 05-31-2015, 02:45 PM Thread Starter
Update: turns out the regulator is fine. Did an voltage test on the stator and it is the culprit. Only making 2 volts on one wire. 20 on the other two.
Dutch is offline
Gen 1: stator and regulator lil_laoboi_904 Wanted: Buy or Trade 3 11-01-2013 12:59 PM
Gen 3: Looking for a stator/regulator JesseN13 Wanted: Buy or Trade 8 09-18-2012 12:26 PM
WTB Gen 2 Stator and regulator Manimal15611 Wanted: Buy or Trade 2 05-19-2012 07:36 AM
Stator or Regulator JaydeeZX10 Performance and Tech 21 11-12-2010 10:27 PM
