Gen 2 making 185 hp?? - Kawasaki ZX-10R.net
post #1 of 7 Old 09-23-2012, 09:45 AM Thread Starter
killerkawi's Avatar
So I have been reading and reading and reading and I have a lot of little questions that I haven't been able to get a full anwser to by reading old posts. First, How much power has someone made with a gen 2. I want to know if you can make 185 hp like the new 10s without having to turbo or spray. I have done the following mods: got rid of the cat, yoshi duals that im soon changing to two bros, secondaries butterflys removed, pc3 on order, tre, and going to do the servo eliminator mod. what else is there to do? I have done this all before except the servo mod on an older bike, but when I did it then my bike was brand new and I didn't have any newer competition per say. I also want to know if when I do the servo mod will i lose on the low end? Even with dyno tuning will it make the hp back?
killerkawi is offline
post #2 of 7 Old 09-23-2012, 10:24 AM
Evil10's Avatar
you can get close with a thinner head gasket, cams, akrapovic exhaust, pcs ignition module.
Evil10 is offline
post #3 of 7 Old 09-23-2012, 11:28 AM
Slow Poke
bgmagma10's Avatar
Really for one it depends on the dyno too. Some dyno's read higher than others. If your so worried about numbers, then a true 185 horse is very hard to make on a gen 2. Sure you can make that much power but you will have to have some much compression you wouldn't be able to run pump gas. Depending on what your bike baselines at on the dyno thats close to you, you can mill the head and put a thinner HG on it, 13.5.1 Je's, an 08 kit cam, and tune on MR12 and that will get you as close as possible. Like said get rid of the duels and lighten it up with a single pipe. Get rid of the the exhaust servo, if your not drag racing get a 520 conversion, and get some good wheels. Just IMO
bgmagma10 is offline
post #4 of 7 Old 09-23-2012, 12:09 PM
gazx10's Avatar
yeah, it can be done. porting, good ex. more compression, cam or cams, tb mods, radius valve seats, custom tune, good fuel.
gazx10 is offline
post #5 of 7 Old 09-23-2012, 06:55 PM
Bmore-stunter's Avatar
Im trying to get close to that number my self. I've got all the mods and I sould be putting my bike back together in the next 2weeks I hope and we will see
Bmore-stunter is offline
post #6 of 7 Old 09-25-2012, 06:56 PM Thread Starter
killerkawi's Avatar
Sweet thanks for the replies. I wouldn't say hp is a huge issue but just like to know if I was pushing for a reasonable number. I just like building stuff and making them fast. Bmore stuneter you'll have to let me know when you get done how you made out with your project. Thanks again.
post #7 of 7 Old 09-25-2012, 08:59 PM
Will do and you do the same
Making Some Noise :) sullysZX10r Pictures and Videos 12 04-04-2013 09:04 PM
Gen 2: She's making some noises. hellboytt Performance and Tech 13 10-08-2011 12:52 PM
Making My Own Tag Bracket hellsrazor The Out House 17 05-13-2011 04:09 PM
Making up for bad personality JUPJON Pictures and Videos 2 05-11-2008 02:25 PM
Making a Entertainment PC RickRoush03 The Out House 6 02-07-2007 08:05 PM
