The Gen 2 Engine for Torque - Kawasaki ZX-10R.net
post #1 of 3 Old 06-02-2013, 01:53 AM Thread Starter
Hi All
I race speedway sidecars and am currently running a Gen 2 2006 ZX-10, I am currently looking at a project to pretty much just throw money at the engine
I am racing on dirt so I am not looking for horsepower that much as this will just cause the rear wheel to spin, I am really after torque
What I would like from you guys is the ultimate engine from torque in regards to parts and such ... and if possible links to sites where I can buy them
So something like the below
Crank -
Cams -
Plugs -
Pistons -
Etc...
Thanks All
Adam
Team Thompson Racing
Go Fast or Go Home
Http://www.teamthompsonracing.com
Delpidus is offline
post #2 of 3 Old 06-02-2013, 08:23 PM
bugman53's Avatar
Do a stoker crank shaft. That will get the power down to a lower rpm and increase torque. You can have custom cams ground to make more torque also. Then get the compression ratio around 14/1(needs race gas). That will get you a good start. Then you want an exhaust tuned for midrange as most are tuned for high end.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #3 of 3 Old 06-08-2013, 10:37 AM Thread Starter
What is a stoker crank shaft? or where can I get one? ... yeah got custom cams, ground to torque ... compression ratio with the new rods and pistons I am putting in there is currently 13.5/1, we are only allowed to run methanol though? ... yeah will have to swap out the current exhaust on it
Thanks for your reply
Adam
Go Fast or Go Home!
Delpidus is offline
Torque setting on the engine mount bolt Kawawog The ZX-10R 0 03-27-2012 03:44 AM
LH engine cover torque spec? BlackRifleTrucker Performance and Tech 13 08-14-2010 09:48 PM
Engine mount bolts- torque tension? Expensivetoylover Performance and Tech 1 02-28-2007 07:02 AM
2005 636 engine mount torque specs... STREETFIGHTER50 ZX-6R & ZX-6RR Archives 2 11-19-2005 09:53 AM
engine mount torque #? kuzco Performance and Tech 4 09-12-2004 05:29 PM
