Gen 2: 2006-2007 Gen 2: Clutch problems - Kawasaki ZX-10R.net
post #1 of 9 Old 06-26-2012, 08:45 PM Thread Starter
cweeks's Avatar
I've been hearing a noise from my bike while holding the clutch in, somewhat like a throwout bearing whine on a car. For this reason I decided to open up my clutch cover and check everything out. I found an awesome how-to thread on here the was pretty much step by step, apparently I messed up somewhere along the way. I pulled my clutches out, they all looked to be in decent shape, I then proceeded to measure each fiber plate to make sure they were within the accepted parameters in the manual. I found that they were all fine and checked out. At this point I started to put everything back together, using the manual's diagram, which had both of the "spring" ring and the flat ring placed behind the second set of plates and fibers. I packed all the rest of the clutches back in, torqued everything to specs, and buttoned it up. I cranked the bike while it was still in the air and the clutch is not engaging, and yes the clutch has been adjusted to both extremes still with no results. The bike has been down for over a month and I was pretty frustrated so I took it to the dealer, where it has been for a week and a half untouched, its a 30 minutes fix which makes that unacceptable. I plan on picking it up and trying to fix it myself. Does anyone know of any common mistakes I could have made?? Any help would be appreciated!
cweeks is offline
post #2 of 9 Old 06-26-2012, 09:08 PM
Stack height too high...Should have a small grove inside the clutch cover..if it looks like more material was grinded away...there u have it...spring ring and flat ring should go in first FYI
06green is offline
post #3 of 9 Old 06-26-2012, 09:19 PM Thread Starter
cweeks's Avatar
As in the first thing in the entire stack? Before any pressure plates or fibers?
cweeks is offline
post #4 of 9 Old 06-26-2012, 09:27 PM
Sorry had to check parts diagram...spring and flat ring go in after 1st steel in the pack
06green is offline
post #5 of 9 Old 06-26-2012, 09:35 PM Thread Starter
cweeks's Avatar
That's where I placed it, I also, with the ring facing the correct way. I thought you'd come up with an easy fix for a second! I'm sure its something simple.
cweeks is offline
post #6 of 9 Old 06-26-2012, 10:26 PM
TexasRider's Avatar
is there any firmness on the lever? or does it pull very easy? are you 100% you have that clutch arm (part #13102) installed correct? Just my suggestion...
Faster than a drunk snail on valium!
07 zx10r- stolen
New bike...07 GSXR1000..BMC filter, LOR slip on, 520 conversion with -1, speedohealer, pc3 custom map with xtre settings, Galfer superbike lines front, galfer sportbike line rear, shorty levers, Yami R1 throttle tube for 1/5 throttle, PAIR mod, exhaust valve gone, ecu flashed.
TexasRider is offline
post #7 of 9 Old 06-26-2012, 11:43 PM
Post Whore
-Op-'s Avatar
This was going to be my question actually.
When you reinstall, you need to take the part that comes out of the clutch cover and rotate it 180* and then push it down and rotate back 180* for it to grab the rod inside. If you did that and still no firmness, the first time I ever did my clutch I screwed up and put the rod that is supposed to pull the clutch apart on the wrong side of the hub you bolt the springs into, the rod should go in first.
-Op- is offline
post #8 of 9 Old 06-26-2012, 11:57 PM
Did put the pushrod in then the pressure plate?
Notguilty is offline
post #9 of 9 Old 06-27-2012, 09:41 PM Thread Starter
cweeks's Avatar
Op, that's how I installed the clutch arm. Texas, as of now the clutch has the same amount of tension on it prior to pulling the clutch. Not guilty, the order of installation was 1) insert clutch pack 2) insert pushrod 3) Insert outside plate(pressure plat) 4) Torque everything and button it up. Thanks for the info guys!
cweeks is offline
Gen 1: Need help with clutch problems... dude The ZX-10R 9 06-12-2012 11:00 AM
Clutch problems? REDVENOM The ZX-10R 24 05-16-2012 04:02 AM
clutch problems bumblebeebob The ZX-10R 0 06-29-2009 05:18 AM
Clutch Problems crowdpleazr Performance and Tech 6 11-28-2007 02:58 AM
clutch problems maybe? KDW Performance and Tech 7 09-27-2005 06:33 AM
