Gen 1: 2004-2005 Gen 1 Zx10 transmission shaft get tight when you tighten clutch hub nut - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By michael4012
  • 1 Post By teror1sta
post #1 of 5 Old 10-28-2018, 09:20 PM Thread Starter
Transmission input shaft gets tight when I tighten clutch hub nut
Zetnam is offline
post #2 of 5 Old 10-29-2018, 01:06 AM
michael4012's Avatar
Did you forget the disc that sits behind the flywheel on top of the drive shaft bearing the one with a "O" marked on it?
theatiss likes this.
michael4012 is offline
post #3 of 5 Old 10-29-2018, 01:42 AM
theatiss's Avatar
I think this is the solution to the problem. I have done it once
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #4 of 5 Old 10-29-2018, 05:58 AM Thread Starter
What disk would that be behind flywheel
Zetnam is offline
post #5 of 5 Old 10-29-2018, 12:28 PM
badassjake likes this.
teror1sta is offline
Gen 2: zx10 transmission shaft disassembly samizx7 The ZX-10R 3 10-15-2011 02:03 AM
clutch hub nut removal slimegreen Performance and Tech 7 05-13-2008 07:59 PM
Oil filter, how tight is tight enough? YSR50 Performance and Tech 21 08-18-2007 07:52 PM
How do you tighten the *&%# nut? ZX10man Performance and Tech 23 01-04-2007 02:33 PM
clutch hub nut question Vince10R Performance and Tech 9 08-25-2006 01:09 PM
