Gen 1: Whirring noise - Kawasaki ZX-10R.net
post #1 of 12 Old 07-11-2012, 10:13 AM Thread Starter
Can anyone tell me if they have experienced this noise.? What it could be Usually is happening at steady cruise. 40 to 50 miles an hour. Then again at 75 to 80. Been looking at a few archive threads and some have said it could be the front sprocket? or flywheel or clutch bearing? maybe wheel bearings? I have been ignoring it but its annoying the hell out of me now.
The sound is not a constant steady noise it seems like its every other revolution at steady cruise. I pull in the clutch at cruise and it goes away.
Cruising above 80 its harder to hear but pretty loud at 75 to 80 for sure.
anyone any thoughts?
freezerburn is offline
post #2 of 12 Old 07-18-2012, 07:41 PM
bugman53's Avatar
My 05 has done that since day 1 at 72MPH and i have seen a few others do it as well, Its a resonating in the transmission seems to me normal and should not cause any problems,
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #3 of 12 Old 07-18-2012, 08:24 PM Thread Starter
Okay cool!! Thanks bugman!!
post #4 of 12 Old 07-29-2012, 01:33 PM
bhoffco's Avatar
Send a message via Skype™ to bhoffco
I have this same issue on my 2007.
The noise is kind of like a turbine or whirrr noise and seems to be loudest at a steady pace when throttle is required to maintain speed.
It is definatley a drive train or trans noise. Very annoying.
I used to only hear it when on steep moutain grades with a passenger but now it happens alot with 25k miles.
I recently changed my sprockets to -1 + 1 and it is more noticable now. It is almost a harmonic noise at 80 mph.
No loss in performance however. I have to resolve it but am not sure where to start.
bhoffco is offline
post #5 of 12 Old 07-30-2012, 02:38 AM
bugman53's Avatar
on my 05, I did a complete rebuild at 3k miles and it was there before and after and everything in the trans was to spec. Its just nature of the beast. I'm sure what the OP and mine are doing is the same thing.
I'm not so sure bhoffco has the same problem that sounds more like a worn chain. Did you replace the chain with the sprockets?
Greeensboro NC
bugman53 is offline
post #6 of 12 Old 07-30-2012, 03:33 AM
Post Whore
-Op-'s Avatar
Another thing it could be for bhoffco is the front sprocket. Depends on what brand. I just threw a 16T Renthal on mine and it makes a bit more of a pronounced noise.
My 05 makes the same sound you guys hear too. Almost sounds like a combination of what you would imagine the chain sounds like spinning at high speed and a forced induction motor. I think its the trans and the ram air.
-Op- is offline
post #7 of 12 Old 07-30-2012, 08:43 AM
dude's Avatar
Same with my '05. Keep riding!
dude is offline
post #8 of 12 Old 07-30-2012, 01:14 PM
Brian24's Avatar
My 05 makes the exact same noise, if she's running good I wouldn't even worry about it. My 600rr made a very similar noise as well.
Brian24 is offline
post #9 of 12 Old 07-30-2012, 02:19 PM
tone.r's Avatar
My 04 too I drives my crazy I keep thinking my motor is hurt.
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #10 of 12 Old 07-30-2012, 09:17 PM
bhoffco's Avatar
The chain was replaced along with the sprockets. I also thought the chain could be too tight but it is adjusted properly.
I am pretty sure it is being caused by something spinning. Probably a bushing or bearing somewhere.
bhoffco is offline
Gen 3: Need Help with noise!!!!!!!! SickAsHellTom Performance and Tech 9 03-21-2011 08:17 PM
whirring noise THECYKOTIK1 Performance and Tech 6 11-27-2008 09:37 PM
tic tic noise V-Force The ZX-10R 14 07-21-2007 06:17 AM
noise from 04 10r grego10r Performance and Tech 11 07-28-2005 01:48 AM
Odd noise... hillcountry10r The ZX-10R 28 12-08-2004 12:40 PM
