Gen 1: Vortex Rearset Disassembly? - Kawasaki ZX-10R.net
post #1 of 10 Old 05-14-2013, 10:42 AM Thread Starter
stage5's Avatar
So I bent the brake lever on my gen 1, and ordered a replacement directly from vortex. The bike came with the rear sets so I don't know what kind of directions I would undo to get the peg off. The lever rotates freely around the peg when the bolt is removed. My question is, what's the easiest way to get the brake lever off of the peg? I've tried a few things but no success.
See pic for detail
Uploaded with ImageShack.us
Thanks
stage5 is offline
post #2 of 10 Old 05-14-2013, 10:50 AM
skidooboy's Avatar
take the rear set off, it probably has a bolt or screw holding it to the bracket on the back. Ski
May we all, get to have a chance to ride the fast one, walk away wiser when we crash one, keep hopin that the best one is the last one.
skidooboy is offline
post #3 of 10 Old 05-14-2013, 11:14 AM Thread Starter
stage5's Avatar
Yes it does but the bolt just secures the bracket to the peg. The lever and peg are what's together and I can't separate. The peg and lever are connected with bearings in between.
stage5 is offline
post #4 of 10 Old 05-14-2013, 01:19 PM
tjunkie's Avatar
Never had vortex, but there should be a bolt screwed into the foot peg. That bolt goes through the mounting bracket, then a bearing on the lever and into the peg to hold it all together... It should just fall apart after you remove it
I can't tell by your last post if you removed that bolt and it's still stuck together? Id probably put the peg in a vice and hit it if that's the case.
tjunkie is offline
post #5 of 10 Old 05-14-2013, 01:32 PM Thread Starter
stage5's Avatar
It's def. not falling apart. I removed the bolt and everything I just posted a pic of the whole assembly. I'll try clamping it and giving it some force. I was thinking I could tap it out with a screwdriver in the bolt hole but that wasn't working and I didn't want to break anything, so I stopped before I got too frustrated and would for sure break something.
Thanks for the help I'll try it this evening.
stage5 is offline
post #6 of 10 Old 05-14-2013, 10:58 PM Thread Starter
stage5's Avatar
So I tried everything listed above, and then some, to try to get the damn peg and lever separated. None of them worked. It's like I have to have a bearing press or some kind of extreme concentrated force tool to get it to pop. Any other suggestions?
stage5 is offline
post #7 of 10 Old 05-14-2013, 11:13 PM
Manny253's Avatar
Had the same thing happen on my rear set. I have the same set installed on my bike.
It comes on off easily, the problem is when it gets bent it kind of jams in there. I ended up getting a new peg and lever.
To get it out I put it in a vise and had to force it out. Broke the inner bearings in the process. Thus why I had to order both.
As long as its all still straight it comes on and off very easily. Only thing holding it is the 1 bolt in the back.
Not sure how the lever was bent since I bought the bike that way.
There might be something else going on for you but in my case this is what happened.
You might just have to ruin the peg and lever in the process like me.
Not sure how helpful this is..
Manny253 is offline
post #8 of 10 Old 05-17-2013, 02:58 PM
tjunkie's Avatar
Get it hot and smash it off. metal expands quite a bit.
tjunkie is offline
post #9 of 10 Old 05-17-2013, 03:03 PM
Crash Test Dummy
Hernando's Avatar
Send a message via Yahoo to Hernando Send a message via Skype™ to Hernando
cut it off
Bear Jew
Hernando is offline
post #10 of 10 Old 05-17-2013, 09:38 PM Thread Starter
stage5's Avatar
I just bought a new peg. Shit did NOT want to come off.
stage5 is offline
Gen 4 vortex rearset issue Joel The ZX-10R 6 09-10-2011 05:09 AM
3rd Gen Vortex Rearset Troubles Candy08 The ZX-10R 6 04-16-2010 02:19 PM
Vortex rearset?.... ZX10Rice The ZX-10R 7 03-05-2010 09:46 AM
Vortex Rearset Intall? SAkI Performance and Tech 0 10-23-2008 10:33 PM
vortex rearset for 07 stecson Vendors deals 2 07-07-2008 09:12 AM
