Gen 1 speedo info please - Kawasaki ZX-10R.net
post #1 of 20 Old 01-08-2011, 11:16 PM Thread Starter
smokerider 666's Avatar
Hi guys - I have an Australian Gen 1 with a damaged speedo cluster & the lcd section is unreadable.
I have tried for 3 months to source one here in Oz but its looking grim. Seems like ebay Us & Uk is the way to go.
Does anyone know if a US or Euro spec speedo would connect & work as normal? We have the immobilizer ignition system here same as the Euro models & I've noticed Us spec clusters have US stamped on the back which leads me to think they might not adapt??
Any suggestions?
smokerider 666 is offline
post #2 of 20 Old 01-08-2011, 11:20 PM
bluedevil's Avatar
For a 1st Gen the Kawi Manual makes NO notice there is a difference....both can be programed for MPH or KPH as well.
bloo
bluedevil is offline
post #3 of 20 Old 01-09-2011, 09:10 AM Thread Starter
Just noticed on ebay that the US spec speedo display does not have the key symbol warning light that flashes when the ignition immobilizer is on.
This is positioned directly opposite the low fuel warning light on the Euro & Australian spec clusters.
post #4 of 20 Old 01-10-2011, 05:11 AM Thread Starter
I spoke to my local dealer today & he could'nt tell me if a US spec cluster would work without problems on my bike.
He did hint that a euro spec is probably the better way to go due to the ignition cut off & then suggested if I buy a new cluster from him he would do me a good deal.
Cost = $1150 'ca-chinnng'!!
post #5 of 20 Old 01-10-2011, 05:58 AM
tasos's Avatar
Do you mean the FI light?
I also think the speedos should be the same, they can be programmed km/miles and C/F.
tasos is offline
post #6 of 20 Old 01-10-2011, 06:30 AM
Flipr's Avatar
On the Aust models we have an Immobiliser as standard equipment.On the Gen 3 there is a flashing red light on the r/h side of the cluster down the bottom(directly opposite the low fuel light).Not sure about the Gen 1.I'd imagine it to be in the same spot.
Mine starts flashing as soon as you turn the key off.Also there is a flashing image of a key on the screen.
Flipr is offline
post #7 of 20 Old 01-10-2011, 07:03 AM
tasos's Avatar
Yeah man i remember something about a key image but couldn't find it on the manual...Need to recheck
tasos is offline
post #8 of 20 Old 01-10-2011, 10:52 AM
Supercharged Mod
The North American spec cluster doesn't have the flashing immobilizer LED ... but the factory service manual makes absolutely no mention of it, either. It's probably not essential for the function of the immobilizer system - but there's not really any way to know that. Some of these security-related systems are deliberately not fully documented.
GoFaster is offline
post #9 of 20 Old 01-10-2011, 11:15 AM
Quick10's Avatar
Will it run without the cluster? I know the US models will.
Quick10 is offline
post #10 of 20 Old 01-10-2011, 05:28 PM Thread Starter
Good idea! I will disconnect the cluster & try to start it
Anyone have info on...... Spyterman The ZX-10R 6 04-18-2008 09:39 PM
Need help or info on something. ar2d2 The Out House 1 03-29-2007 03:19 AM
need sum pay pal info plz SUPER K The Out House 6 03-23-2006 04:21 PM
Speedo info and Aprilia Mille Stuff ZXtasy The ZX-10R 1 07-21-2005 01:23 AM
