do the gen 1 use the throttle mod too like gen 2?
aside from exhaust, zx14 or zx6 brakes upgrade with brembo master, air filter, block of plates, flash/tune, welded basket or nitrous/turbo
what are other mods or little tricks yall do to these gen 1s
Couple things u can do is remove sec flies, undo exhaust valve cables, ditch the auto cct for manual adjuster, -1 front sprocket, 1/5th throttle mod, good pipe and tune
sec came removed, about to remove the servo cables soon yup, auto cct ? what is that? sprockets going -1 back. and throttle mod ok like the gen 2 just need to find if the guy still makes it. yeah also looking for a full exhaust
+3 in the rear is about the same as -1 up front, im sure you knew that already
Related Threads
Kawasaki ZX-10R Forum
2.1M posts
128.9K members
Since 2003
