Gen 1 idle problem - Kawasaki ZX-10R.net
post #1 of 10 Old 03-29-2011, 10:47 PM Thread Starter
zx racer's Avatar
Gen 1 idle problem
hey guys i recently chop down my muzzy pipe and now my bike doesnt idle the same. before i cut the pipe it would idle smoothly at 1100rpm cold and 1300rpm warm. just wondering if anybody has experienced this ? if so what did you do to fix it.
zx racer is offline
post #2 of 10 Old 03-29-2011, 11:09 PM
Touring-Jay's Avatar
Your normal idle should be 1,100 rpm (+) or (- 50). 1300 is a tad high.
Touring-Jay is offline
post #3 of 10 Old 03-29-2011, 11:14 PM
wheeliest's Avatar
Send a message via AIM to wheeliest
i run my idle at 1300 to. no such thing as to high.. its preference. turn it up.
wheeliest is offline
post #4 of 10 Old 03-30-2011, 12:02 PM Thread Starter
zx racer's Avatar
my bike has always idle at 1100rpm cold and once the temps go up it idles at 1300rpm. im thinking i might have to bump the idle up a lil or adjust the pc some.
zx racer is offline
post #5 of 10 Old 03-30-2011, 12:30 PM
RainOrShine's Avatar
There is a little knob on the side of the bike. Just turn it up a little bit. You probably rub against it and turned it down by accident...or natural vibrations
RainOrShine is offline
post #6 of 10 Old 03-30-2011, 03:24 PM Thread Starter
zx racer's Avatar
i will bump up the idle some and see how it goes.
zx racer is offline
post #7 of 10 Old 03-30-2011, 04:47 PM
well what'd you do that for goober..
06green is offline
post #8 of 10 Old 03-30-2011, 04:52 PM
^^No Bike Bum^^
cbolton69's Avatar
Send a message via Yahoo to cbolton69
did you take alot of the packing out of the exhaust to make it louder by chance???
my guess would be you changed you back pressure and prolly need to get your PC adjusted
cbolton69 is offline
post #9 of 10 Old 03-30-2011, 05:10 PM Thread Starter
zx racer's Avatar
yea i cut about 10 inches off the can just for looks and sound. before i cut the can it idle fine around the rpms i mention earlier but now its not as smooth. i was thinking it was bc i lost some back pressure and might have to adjust the pc some. do you think i need to richen it some ? if so how much do you think.
zx racer is offline
post #10 of 10 Old 04-06-2011, 10:07 AM
wrisktakerz1's Avatar
i have the same situation, i wouldn't call it a problem but I cut down my muffler as well and now experiencing the same result. My theory is when you cut the pipe you change the characteristics of the exhaust note, backpressure, and wave length, therefore you'd might have to bump up/turn down the idle to compensate. Just look at racebikes mainly motogp for instance, most of the bikes have 2 or 3 inch mufflers if any at all and they idle around 5-6000 rpm. In my opinion, just turn it up some.
wrisktakerz1 is offline
idle problem nyrep1 Performance and Tech 4 07-12-2009 03:34 PM
idle for 10r? OneSLOW10 The ZX-10R 41 04-17-2008 01:37 PM
idle speed problem (2004 ZX) K.makry Performance and Tech 7 06-07-2007 05:47 AM
Idle RPM nachszx Performance and Tech 14 04-21-2007 01:36 PM
Idle Problem...Maybe gguff The ZX-10R 14 03-02-2005 05:36 AM
