Gen 1 generator question - Kawasaki ZX-10R.net
post #1 of 5 Old 12-15-2014, 06:33 AM Thread Starter
Matteson's Avatar
Pulled the motor and I installed the new generator in the motor and was reading the manual about how to install it to spec and in the manual it says to add grease to the oil seal lip before mounting the shaft lever. Do I pull the little oil seal and grease the circumference of it? Or put the seal in, slide the shaft through and then grease the outside? Any help would be awesome. Just trying to get it put back together.
Super easy motor to pull by the way. Also can the clutch, starter cover gaskets be reused?
Matteson is offline
post #2 of 5 Old 12-15-2014, 08:26 AM
keithk's Avatar
I would just grease it then install, when I did mine I didnt grease it at all and I reused the gaskets and it was fine.
Its green and it says Kawasaki ninja zx10r on it!
keithk is offline
post #3 of 5 Old 12-15-2014, 09:02 AM Thread Starter
Matteson's Avatar
Thanks, thats what I will do.
Matteson is offline
post #4 of 5 Old 12-16-2014, 06:05 AM
dharmon012's Avatar
did you match letters. i believe there are three styles of generators A,B,C
15 ZX10R
91 Harley Fatboy
04 ZX10R - Burned in front of my eyes
00 R1 - Stolen & Crashed
98 ZX6R - SOLD
dharmon012 is offline
post #5 of 5 Old 12-18-2014, 02:27 PM Thread Starter
Matteson's Avatar
Ya, I got lucky and the generator mated to my clutch gears. I cross referenced the numbers and they would work with the clutch I currently have. So I didn't have to change the gear on the generator shaft. Thanks again Tyler for all the help!
Matteson is offline
Trackday Generator Question modpup General Motorcycle Discussions 7 08-30-2011 08:12 AM
Will a 2nd gen kit generator fit the 3d gen? Balogiannis Performance and Tech 10 12-19-2010 01:58 AM
gen 1 generator ??? inginekilla Performance and Tech 2 12-16-2010 05:15 PM
Kit generator question Bigcat#44 Performance and Tech 11 01-24-2010 01:35 AM
Generator Question hale Performance and Tech 6 05-20-2006 07:42 PM
