Gen 1 fuel pump not getting power ??? - Kawasaki ZX-10R.net
post #1 of 3 Old 01-22-2019, 08:49 AM Thread Starter
Hi I'm not getting power to my fuel pump no priming noise and have checked with a metre any ideas on what I can check out next as it's really frustrating me now
Denred is offline
post #2 of 3 Old 01-22-2019, 11:52 AM
Kawasaki Whisperer
MrMoto73's Avatar
Send a message via MSN to MrMoto73
I am guessing you checked your fuses and grounds? Does it have a power commander? Also there are a couple of sensors that cut power to the pump. Lean angle sensor, kick stand sensor.... can't remember what other ones.
I DON"T HAZ ANY SNYDER PROBLEMS
MrMoto73 is offline
post #3 of 3 Old 01-22-2019, 10:40 PM
gaz
as stated ck kickstand switch. i've had 2 10's lost pump power. after switch first place i would go is the common ground box located in wiring harness directley at the end of the negative battery cable. rectangular plastic box taped up in main wiring harness close to where fuel pump power plug comes out. serves as ground for several sensors/systems. untape and pry apart to ck for burnt wiring/corossion. also common +12v box same position can cause multiple problems. spent hours chasing down the first one, had a burnt wire, next one was corossion problem, repaired/cleaned pump power restored. not hard to check.
gaz is offline
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 06:13 PM
fuel injector or fuel pump??? Dnicezx10r The ZX-10R 2 12-13-2011 07:16 AM
Fuel Injectors and Fuel Pump Crazi Parts, Gear and Accessories 0 10-21-2009 07:42 PM
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 10:39 AM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
