Gears slipping? - Kawasaki ZX-10R.net
post #1 of 6 Old 11-04-2010, 02:44 PM Thread Starter
bun1t's Avatar
Gears slipping?
I went for a quick ride today and I had a wot run thru a few gears. When I shifted into 6th and it revved out like it was neutral. I was using my quickshifter also. The bike only has 2500 miles so I doubt it could be a clutch issue this early. Is it possible for the transmission to get caught between gears?
Btw it's a 2005 zx10r
bun1t is offline
post #2 of 6 Old 11-04-2010, 05:03 PM
SkyDork's Avatar
Your gears can't slip. They are a constant mesh design and the gear pairs interlock through a set of "dogs" on the sides of each gear pairing.
What you're likely experiencing is a "false neutral", or like you said, caught in between the gear pairings. This can sometimes occur based on an incomplete or sloppy shift or from worn tranny parts. If you were able to press the gearshift lever and get it into gear and it didn't repeat itself, then it's probably just one of those random things. If it continues and is repeatable, then you've got other transmission issues (worn shift drum, worn shift forks, etc.) and it will only get worse unless fixed.
#WordCrimes
SkyDork is offline
post #3 of 6 Old 11-04-2010, 05:51 PM
tone.r's Avatar
well said
tone.r is offline
post #4 of 6 Old 11-04-2010, 06:01 PM
09zx10miami's Avatar
09zx10miami is offline
post #5 of 6 Old 11-04-2010, 06:26 PM
sam_b03's Avatar
How long has it been since you changed your oil. I know if I go too long on the same oil my trans will not shift as nice. If I get a bad shift or notice it takes more effort to work the shifter new oil is needed.
sam_b03 is offline
post #6 of 6 Old 11-04-2010, 09:17 PM
zx racer's Avatar
sounds like a bad clutch me. if it was the tranny i would think it would do in all gears not just 6th.
zx racer is offline
clutch slipping meanstreak5 Performance and Tech 24 05-03-2008 10:37 PM
HELP!!! Clutch is slipping!!! zx10ragentblack Performance and Tech 46 02-15-2007 12:51 PM
Slipping & sliding danno46 Pictures and Videos 8 02-12-2006 06:35 PM
Another slipping Clutch bluedevil Performance and Tech 10 06-30-2005 02:13 AM
Slipping clutch Paul Sonderfan The ZX-10R 8 05-08-2005 12:47 PM
