Gearing Change- Chain Length Question - Kawasaki ZX-10R.net
post #1 of 5 Old 12-17-2014, 10:00 PM Thread Starter
Hey Folks,
I have Gen3 and am planning to go +2 in the rear. I am staying with the 525 chain gauge. However, the stock length is 110 links. How much longer would I need to go? I think that 112 lnks would do it since the sprocket has two extra teeth, or would I need more? Anyone done this and remember what length chain to use?
Thanks!
tom7 is offline
post #2 of 5 Old 12-17-2014, 11:24 PM
Bottoms-Up's Avatar
Stock - 17/41 with 110 links = sprocket distance = 25.2
Custom - 17/43 with 110 links = sprocket distance = 24.87 (-0.33)
Custom - 17/43 with 112 links = sprocket distance = 25.49
What this means is if you have the room to move your axle
up 0.33" you can use the 110 if not use the 112
Check it out at....
http://www.gearingcommander.com/
Gearing Commander is very cool!
Bottoms-Up is offline
post #3 of 5 Old 12-18-2014, 08:23 AM
SkyDork's Avatar
If I remember correctly from mine, +2 should be fine with the stock length.
#WordCrimes
SkyDork is offline
post #4 of 5 Old 12-18-2014, 08:33 AM
zx racer's Avatar
Yep you should be fine with +2 stock chain.
05 ZX-10R SWB.
zx racer is offline
post #5 of 5 Old 12-18-2014, 01:33 PM Thread Starter
Thumbs up Thanks!
THANK YOU!!!!
Two Thumbs up for Gearingcommander
tom7 is offline
Gen 1: chain length question giszo Performance and Tech 19 07-14-2012 08:54 AM
Changed gear ratios, change chain length? Omofo Performance and Tech 6 05-09-2012 05:37 PM
Question about sprocket sizes. How many of you change your gearing? GosuPaintballer Track 14 01-19-2010 01:07 PM
Chain length question ikaika Performance and Tech 9 08-24-2009 07:37 PM
swing arm extensions (chain length question) vorderma Performance and Tech 2 04-20-2007 02:20 PM
