>> Gear Shifter Adjustment << - Kawasaki ZX-10R.net
post #1 of 5 Old 09-08-2018, 12:52 AM Thread Starter
Melampus's Avatar
Question >> Gear Shifter Adjustment <<
I gotta admit that I'm a little embarrassed asking this question as I've made this adjustment a score of times before on other bikes, but on my 1st Gen ZX-10R, it's not cooperating. I'm stumped.
I need to adjust my gear shift pedal lever down as I can barely reach it. I totally loosened the clamp that secures the linkage...
to the main rod that runs through the motor, but I can't get it to slide out & off so I can rotate it on the splines to adjust the pedal lever down. It is loose & it will slide out, but it stops & just won't come all the way off. There are no visible burrs or obstructions that would cause it's travel to cease, but it just stops.
Is there a step that I'm missing on the 1st Gen ZX-10R.?!
Melampus is offline
post #2 of 5 Old 09-08-2018, 02:01 PM
SkyDork's Avatar
You're doing it wrong!
You loosen the locking nuts on the throw rod (red) and then spin the throw rod (blue). The end bearings are opposite threads so it will lengthen and shorten the rod ends which pick the pedal up or move it down.
If you need to move splines on the spindle, the clamping bolt has to be removed completely. The threaded shaft has a groove in it that the bolt rides in. You can't pull it off the spindle shaft if the bolt is in.
Name:	shifter adjust.jpg
#WordCrimes
SkyDork is offline
post #3 of 5 Old 09-10-2018, 02:09 AM Thread Starter
Melampus's Avatar
Wink
SKYD <> Thanks for being there, again.
The reason I chose to adjust by rotating the clamp on the grooved spindle is due to the extreme of the adjustment required. I've always used the throw tube for fine adjustments; sort of analogous to the spindle at the clutch lever as to the lock nut at the clutch cover. Under hard throttle, I have to literally lift my whole foot up off the peg to reach the shift pedal lever. It's terribly upsetting to the chassis at lean, and I have to be uber vigilant in all 1st/2nd upshifts to get a solid engagement since it's such a reach.
I'll try again by completely removing the clamping bolt. Thanks again!
Melampus is offline
post #4 of 5 Old 09-10-2018, 06:57 AM
gaz
i run into it on bikes. shot of wd40, prying with large flat head screwdriver, spreading clevis open with large flathead, probabley all three. but it will come off for needed adjustment.
gaz is offline
post #5 of 5 Old 09-10-2018, 03:11 PM Thread Starter
Melampus's Avatar
Thumbs up
Good lookin out, GAZ. Thank you.
Melampus is offline
WTB 06 07 Engine / motor <<<<<<<<< NMBR1SPT Wanted: Buy or Trade 6 09-14-2013 06:55 PM
>>>>>2008 zx-10r - $6,300<<<<<< swing lo Bikes 4 Sale 12 07-14-2010 11:16 PM
Fellow ZX10 family... Need your support<<<<<<<<<<<< nbrion1 The Out House 25 01-22-2010 07:25 AM
