Gear indicator problem help! - Kawasaki ZX-10R.net
post #1 of 8 Old 03-17-2011, 01:16 PM Thread Starter
madkaw08's Avatar
So I installed my healtech tre about a month ago and everything was working fine. I rode it this morning and my gear indicator was off. It says i was in 3rd, 4th, and 5th when i was in first and second. I rechecked all my connections and everything was solid. I even reset the system and the gear blinked like it should. It still pulls just as hard idk whatt the problem is. Any suggestions??
madkaw08 is offline
post #2 of 8 Old 03-17-2011, 01:37 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
mine did that once and i just had to reset it and "re-teach" the gears real quick BUT i have an 04' with the data tool indicator?
TMY10ER is offline
post #3 of 8 Old 03-17-2011, 01:51 PM Thread Starter
madkaw08's Avatar
Ya I reset it by disconnecting the battery and it works fine sometimes than ill turn it off than turn it back on and itll say im in third when im in first and always be a gear ahead. Than I turn it off and turn it on again and it works fine. It's wierd
madkaw08 is offline
post #4 of 8 Old 03-18-2011, 05:23 AM
Gen2 Ripper
neverendingmods's Avatar
shoot healtech an email. They back their products to be free of defects for atleast a year and will test it for you and replace it if it did go bad even if it's over a year old in most cases. So long as it isn't all beat to shit or damaged in any cosmetic way.
Have you added any new electronics to the bike recently?
neverendingmods is offline
post #5 of 8 Old 03-18-2011, 07:55 PM Thread Starter
madkaw08's Avatar
I installed the pc3 like two weeks prior to that but other than that no.
madkaw08 is offline
post #6 of 8 Old 03-18-2011, 08:35 PM
Post Whore
1killer1liter's Avatar
Images: 11
Did you put it in re-learn mode and go from there?
1killer1liter is offline
post #7 of 8 Old 03-18-2011, 08:55 PM Thread Starter
madkaw08's Avatar
Re learn mode? I just reset it by disconnecting the battery if thats what you mean.
madkaw08 is offline
post #8 of 8 Old 03-20-2011, 09:15 PM
Post Whore
Images: 11
Gear Indicator ghost057 Performance and Tech 4 10-08-2010 04:31 PM
Gear indicator problem KDT4 The ZX-10R 0 04-25-2009 11:31 PM
gear indicator for 05 ZX-10 SoCal90 Vendor Deals 1 07-09-2008 12:16 PM
Top Gear Indicator? wash23 Performance and Tech 0 12-30-2006 03:56 PM
Anybody ever use this gear indicator? low10 Performance and Tech 10 09-24-2006 02:32 PM
