Gen 3: 2008-2010 Gear Indicator not working??????? - Kawasaki ZX-10R.net
post #1 of 7 Old 05-22-2011, 07:18 AM Thread Starter
stratszx10's Avatar
My GI is not working.I took a healtech Xtre off and now no GI.At first,one of the wires was pulled out in the connector.I pushed it in and it came up for a moment then quit again.Are there fuses.Any ideas.both wires pulled out an I think I put them back in the same position.
What do the 2 wires match up to on the white plug by the tank? thanks
stratszx10 is offline
post #2 of 7 Old 05-22-2011, 05:31 PM Thread Starter
stratszx10's Avatar
I rode today and it worked at times????Must have a loose connection.
post #3 of 7 Old 05-23-2011, 12:16 AM
Pittster's Avatar
down near your front sprocket there is a black sensor that has 2 screws, undo this and there is 2 copper bullets that have pressure put on them from 2 springs so they make contact on the sensor giving which gear indication. Mine was missing gear changes i re tensioned the spring and smoothed the tips of the bullets and came good.
Pittster is offline
post #4 of 7 Old 05-23-2011, 11:50 AM Thread Starter
stratszx10's Avatar
I'll check it tonight.Thanks
post #5 of 7 Old 05-24-2011, 09:15 AM Thread Starter
stratszx10's Avatar
I did this last night and its working.Took a little spin,hopefully it hold up.Thanks pittster
post #6 of 7 Old 05-24-2011, 06:15 PM
Pittster's Avatar
No probs mate keep a one on it cause when i did it the o ring under the sensor didn't seal well so i had to get a new one ($2) i only noticed it had a slow oil leak when i took the front sprocket cover off. Just check it after your next ride.
Glad i could Help
Pittster is offline
post #7 of 7 Old 05-30-2011, 07:17 AM Thread Starter
stratszx10's Avatar
Fixed it.Thanks for the info.It works great!!!!
gear indicator rapid van cleef The ZX-10R 2 12-04-2010 05:34 AM
Gear indicator Adamw Performance and Tech 21 02-01-2010 11:44 AM
gear indicator for 05 ZX-10 SoCal90 Vendors deals 1 07-09-2008 11:16 AM
Gi Pro Gear Indicator Help?? mattfr12 Performance and Tech 18 04-04-2007 04:45 AM
Anybody ever use this gear indicator? low10 Performance and Tech 10 09-24-2006 01:32 PM
