Gauge reading 0 - Kawasaki ZX-10R.net
post #1 of 19 Old 03-13-2008, 11:58 PM Thread Starter
luxurylows's Avatar
Gauge reading 0
Im just putting a ZX10r (05) back together after it was crashed...It was all cosmetic damage. I got a used gauge cluster from another cat on this fourm and everything lights up nice, time, turn signals, temp, works fine but the spedo reads 0, KM dont move when riding?? could this be the speed sensor? I took it off and it seems clean and fine. Is there a way to test it? thanks boys
luxurylows is offline
post #2 of 19 Old 03-14-2008, 12:15 AM
FAF
Rent this space
Could well be, I would check the connections to it, if I remember correctly they are at the side of the airbox.
FAF is offline
post #3 of 19 Old 03-14-2008, 01:26 AM Thread Starter
luxurylows's Avatar
DO the headlights have to be plugged in for the gauge to function fully?? I wouldnt think so but just grasping at idea befor I contact paypal to get a refund for the gauge.. I remeber my buddy runnin street fighter setup with no headlights at all and the gauge functioned fully...??? HELP
post #4 of 19 Old 03-14-2008, 02:05 AM
SecretAgent's Avatar
Send a message via AIM to SecretAgent
no, the headlights do not need to be connected. check the wiring to the guage cluster to make sure it's working properly...download the service manual for the procedure.
SecretAgent is offline
post #5 of 19 Old 03-21-2008, 01:07 PM Thread Starter
luxurylows's Avatar
Well i put in a new speedo sensor and that is not the problem... I am told by the tech that its the gauge itself.. I have been in contact with www.BLUEGAUGES.com and he has said send him the gauge he may be able to repair it.. Befor I do, can anyone help me with tryin to figure this out.. On the circuit board..what part makes the speedo work? and were can i get parts to fix it..thanks
post #6 of 19 Old 03-21-2008, 01:10 PM
ducatiryder89's Avatar
Images: 21
Before you go that far check the lead to the speed sensor. It gets routed throught the left side engine mount and sometimes gets pinched. I did it when I put my came in and was like WTF so a inspected the line and sure enough. Check that before you go spending all sorts of money.
ducatiryder89 is offline
post #7 of 19 Old 03-21-2008, 03:11 PM Thread Starter
luxurylows's Avatar
Yah I did that and tested the wire going through..I just put my buddys 636 gauge on the bike and it is reading the speedo..Its way way way out (doing about 60km and it reads 7km nice and steady).. Its so confuzing because the gauge only has 4600km on it and it lights up nice and everything works but the speedo and odometer... I guess ill send it in to BLUEGAUGES.com and hope for the best..
post #8 of 19 Old 03-21-2008, 04:13 PM
When I was serching ffor my 06 adn looling at othrs I noticed that the speedo cluster has some issues that Kawi indicates are common. I looked at one that read fine for a while when starting to ride then would flash or read 180mph etc. I think it would be wise to contact kawi to see the frequency this issues has been reported to see if it is a manufactureer issue as well. Hope you get it resolved...
SAkI is offline
post #9 of 19 Old 03-22-2008, 12:48 PM
sextaafondo's Avatar
Speed sensor malfunction (the wiring or the sensor itself) or sensor disconnected will shoot error 24 at the FI.
If never showed an FI, then the problem is the cluster.
ID:	62867   Click image for larger version
ID:	62868   Click image for larger version
ID:	62869   Click image for larger version
ID:	62870   Click image for larger version
sextaafondo is offline
post #10 of 19 Old 03-22-2008, 01:48 PM Thread Starter
luxurylows's Avatar
Yah I put a new speed sensor in it thinkin that was it but still the same thing.. I put a gauge from a 06 636 and the speedo worked just way way off... I am told from Bluegauges.com its the gauge becasue we ruled out everything elts(we hope).. I just sent the gauge to him in hopes he can fix it.. I down 40bucks for shipping there and back but If it can be fixed then its worth it
05 ZX-10R Like new $7500 Reading, PA SpeedyG37 Parts, Gear and Accessories 8 06-18-2007 08:25 PM
Temp Reading C 636?? kneedragger Performance and Tech 6 04-08-2007 02:55 PM
GPS Reading on the 10R RickRoush03 The ZX-10R 1 04-10-2006 08:47 PM
odometer reading justoyz2 The ZX-10R 7 10-31-2005 04:07 PM
This one is worth reading.... Austin10RPowers The Out House 12 06-15-2005 01:05 AM
