Gasket & Cams - Kawasaki ZX-10R.net
post #1 of 68 Old 03-08-2005, 08:46 AM Thread Starter
Gasket & Cams
Okay I've researched the heck out of this and I know some of us are very interested in performing this to our bikes.
The most important thing to this is having the correct tools...summitracing.com offers a kit for $85 (part no. SUM-G1056) whereas holeshot racing offers one for $266...Summit ensures me a degree wheel is a wheel, they offer the measurement device in the same .001" increments as webcams and offer the magnetic base just as webcams does. The only other issue is a positive stop device which can be ordered from holeshot for $25 or something; I'm 99% sure you would only need the 12mm ones because I think the plugs on a japansese bike are 12mm. Webcams offers a kit and their number has been busy for two days now so I dont have a price on that kit. Summit also said you can take an old spark plug and remove the electrode and place a steel dowel rod in there to use and that is at a minimal cost.
I'm going to try and make this thread a complete parts listing of everything that will be needed including costs, etc.
I also have skads of links on how to do stuff, it really does not sound hard at all once you understand the theory of finding TDC and measuring for .050" of lift on the BTDC when the lobe moves and .050" of lift ATDC part of the lobe.
If you all want information just let me know in this thread and I will post all of the links here.
If and when I do this I will do a pictoral like El Diablo has done to let those of us who are timid to know it shouldn't be that hard.
BNninja is offline
post #2 of 68 Old 03-08-2005, 09:17 AM
MIA Post Whore
miykl's Avatar
Go BNninja.... get you're cam timing on.. Go BNninja........
Pics, pics, and more pics. you go first, I'll do mine second!
miykl is offline
post #3 of 68 Old 03-08-2005, 09:42 AM Thread Starter
Check these links, they are great and really helped me understand it isn't that hard. My wife will kill me if I melt my pistons or destroy them on the valves, but we start a journey with the first step.
I'm calling Ivan to see if we need any of this other BS dowel pin replacements like the service manual suggests.
http://www.ridgenet.net/~biesiade/camdegree.htm
http://www.fourwheeler.com/howto/67578/
http://www.macdizzy.com/cylinder_map4.htm
These along with the instructions on webcamshafts will make it all clear...like jetting a carb. There is another link on zx-10r-forum.com to an article by Muzzy's. I'm going to pay the $20 and get the videos believe me on that one.
BNninja is offline
post #4 of 68 Old 03-08-2005, 10:00 AM Thread Starter
I talked to Ivan:
He said dont worry about replacing all of the alignment dowel pins, spark plug gaskets, etc. and dont worry about replacing the left side crank gasket, it is copper so it can be reused if you are careful. He told me DO NOT order the summit degreeing kit. You will need to fab something of steel so that it can mount the indicator using the magnetic base since the alloy engine is not magnetic. You also will need to pick up some pieces (bolts, washers, spacers) from the hardware store to secure the degree wheel to the crank.
So parts looks like:
1 x 11061-0051 (top head gasket) $25.81
1 x 92055-0020 (timing cover gasket) $7.05
Figure in $70 for oil change and coolant change & other lubes(moly based per manual)
You can get this done for under $400 and gain 7-8hp.
BNninja is offline
post #5 of 68 Old 03-08-2005, 10:14 AM
MIA Post Whore
miykl's Avatar
head gasket $25? I thought it was $80?
miykl is offline
post #6 of 68 Old 03-08-2005, 10:20 AM Thread Starter
that is the top gasket for the head cover...$25
BNninja is offline
post #7 of 68 Old 03-08-2005, 10:39 AM
Supercharged Mod
The spark plugs for this bike - which is where you thread the top-stop into - are M10x1.0 as on most newer bikes.
GoFaster is offline
post #8 of 68 Old 03-08-2005, 11:08 AM
MIA Post Whore
miykl's Avatar
as in "valve cover" gasket
miykl is offline
post #9 of 68 Old 03-08-2005, 11:08 AM Thread Starter
I just read what ronayers called it...head cover gasket
BNninja is offline
post #10 of 68 Old 03-08-2005, 11:10 AM
MIA Post Whore
miykl's Avatar
there should have been a "??" at the end of my last post. I was looking for a clarification, But I think we're on the same page .
miykl is offline
Pistons & Cams jburmeister Performance and Tech 17 03-08-2005 02:30 PM
high comp gasket install??? on1whl Performance and Tech 2 02-28-2005 07:49 AM
Gasket question jjgi550 Performance and Tech 9 02-27-2005 02:02 PM
I have never had a oil plug gasket? sabersaw30 The ZX-10R 9 02-25-2005 08:16 PM
Anybody make cams yet sweetride10r Performance and Tech 23 12-31-2004 02:10 AM
