gas porting pistons - Kawasaki ZX-10R.net
post #1 of 4 Old 08-04-2008, 01:39 PM Thread Starter
gas porting pistons
I've searched the forum with no luck... Anyone here had their pistons gas ported??? I went with 13.5 JE pistons with an overbore and used their rings... didn't seat... I've been told this has been a problem for several who have done overbores... just finished tearing the motor back down to put in total seal rings and have been told by a few to gas port the pistons... any input???
Thanks Brian
MACHINE is offline
post #2 of 4 Old 08-04-2008, 01:49 PM
Vince10R's Avatar
Thanks Brian
absolute must. They will not seal especially with total seals. I would run the standard ringset and gas port the piston. PM or call Dwayne at Cycle Concepts we went through this on mine.
Vince10R is offline
post #3 of 4 Old 08-04-2008, 01:51 PM
BANNED
The gas ports work GREAT till they clog up with carbon over time. Just be prepared to go back in there again.
JJ
JimmyJam is offline
post #4 of 4 Old 08-04-2008, 03:23 PM Thread Starter
hmm... most everyone has told me to run total seal and not the one that came with the JE's... ????? they never seated for me... put almost a 1000 miles on it... blow by was rediculous...
So you think the total seals are worse huh...
MACHINE is offline
Head porting Nevaeh Speed The ZX-10R 9 10-17-2007 10:20 PM
porting angles fbmbks Performance and Tech 11 10-02-2007 12:53 PM
Cylinder Head Porting pec2903 Performance and Tech 2 07-19-2007 10:30 AM
head porting? speedfreak Performance and Tech 2 03-21-2005 06:24 AM
Porting the heads, as anyone done it? crispin Performance and Tech 21 01-28-2005 02:51 AM
