Galfer brake lines - Kawasaki ZX-10R.net
post #1 of 11 Old 06-28-2005, 09:13 AM Thread Starter
Galfer brake lines
Who has the cheapest prices on the Galfer lines for the ZX-10R. Gonna do the fronts only and am considering the Superbike lines though I will probably go with the regular lines with aluminum fittings if I can get them. Input on the Superbike lines, please as well as the pros and cons of the aluminum fitting lines versus their regular stainless steel line.
swjohnsey is offline
post #2 of 11 Old 06-28-2005, 09:15 AM
RickRoush03's Avatar
Dude, get the reg ss galfers, you won't notice the difference unless your a pro, i have seen them from $80-90 at the stores and online, no real big deals out there.
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
post #3 of 11 Old 06-28-2005, 09:30 AM
Andy's Avatar
Images: 25
Johnsey, I copied this thread to the sponsor section for you.
You'll get a reply for this sort of thing alot faster over there.
https://zx-10r.net/forum/showthread.php?t=9876
Andy is offline
post #4 of 11 Old 06-28-2005, 10:19 AM
I think BnNinja has the superbike lines and wasn't impressed. They're actually 3mm thicker lines than the "regular" SS lines. Braking feel wasn't improved enough to justify the cost.
BTW, I have the SS lines & Galfer HH pads. While vastly better than stock, I still get lots of fade at the track. The real solution is the Brembo MC - which is one the way
SuicideMachine is offline
post #5 of 11 Old 06-28-2005, 10:48 AM
Post Whore
Older Guy's Avatar
I have the Galfer race lines and HH pads (front and rear) and my bike stops RIGHT NOW.
Older Guy is offline
post #6 of 11 Old 06-28-2005, 11:23 AM
Older Guy, does it still stop as hard at the end of a track day?
post #7 of 11 Old 06-28-2005, 12:35 PM Thread Starter
Went with the plain vanilla Gafler lines from Brad at Superbike Supply. At 73 bucks shipped can't really beat the price. Gonna use up the O.E.M. pads before I start looking for replacements.
post #8 of 11 Old 06-28-2005, 01:40 PM
grover's Avatar
Send a message via AIM to grover
I'll be trying them out on the track next weekend.
KRONREIF TRUNKENPOLZ MATTIGHOFEN
grover is offline
post #9 of 11 Old 06-28-2005, 02:05 PM
Rspec99's Avatar
Images: 11
The Galfer superbike lines are 2.7mm versus the regular SS lines are 3mm. The smaller diameter lines should provide a slight improvement in bite, and because they do not use a banjo bolt there should be a slight improvement in brake feel.
A few people have indicated some issues with leakage with the SBK lines. According to Galfer, the caliper mounting is quite fragile and should only be tightened to their specs (which is lower than the stock banjo mount).
I myself ordered the the SBK lines and have yet to mount them. I'll try to provide some input when I got these installed with my Brembo MC.
Rspec99 is offline
post #10 of 11 Old 06-28-2005, 08:53 PM
Post Whore
Older Guy's Avatar
Dunno...first track day is August 2nd at Buttonwillow...
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 05:58 PM
Galfer Brake Lines, EBC HH Pads, Fluid - $130 Shipped. Solo-Moto-Parts Vendors deals 17 01-16-2005 01:40 AM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 03:27 PM
MD Product Review: Galfer's Sintered 1375HH Brake Pads and Brake Lines and Waves flatout Performance and Tech 4 11-04-2004 12:29 PM
Member Special: Galfer SS Brake Lines & HH Pads Cal-Sportbike Vendors deals 8 07-31-2004 11:11 PM
