G.I. Pro help needed - Kawasaki ZX-10R.net
post #1 of 22 Old 11-13-2008, 02:52 PM Thread Starter
Ducati Killer's Avatar
Images: 7
Installed the G.I. Pro with TRE on my 2005 ZX-10 and can't seem to get it to work properly. Once installed with the default settings, took for a test ride and shows 1st and 2nd gears fine but only sometimes 3rd and rarely 4th, 5th & 6th. It would even go dim and shut off momentarily when it would go as high as 5th or 6th gear showing.
I then did the self learning procedure per the instructions. Then back out for a test ride. Well...it was a little better but basically still same problem ie: shows wrong gear, etc..
So then I started over...double checked all connections which did result in finding that one of the plugs had one or more its wires not pushed in all the way. So I ensured that they all were then snapped all back together and then back out for a test ride after resetting back to the default settings.
Well....this time, it still had the same problems minus the dimming and shutting off and back on problem. So I then did the self learning procedure again then back out for another test ride. This time it was still having the same problem but just a little better.
I then e-mailed the tech support and gave the same description as above. The response was to check the connections, and even re-route the wires away from other cables and re-do the learning procedure....which I have'nt got around to doing yet.
Has anyone had any of these same problems ? and if so, what worked for you ? Any input would be appreciated.
Thanks, Alex
Ducati Killer is offline
post #2 of 22 Old 11-13-2008, 07:26 PM
Daves Cycles's Avatar
When your doing the learning proceeder how are you doing it?
I get the best results by having the bike on my Vortex rear stand (sitting on the swingarm spools).Get on the bike and start it.Start the learning process. Shift thru the gears went they are displayed.Giving the engine just a little throttle in each gear to help the transmission shift.
05 green ZX10R,Akrappovic Evo 2 Carbon w/ hex shorty can full exhaust system,Power Commander USB,Radial front master cylinder(636),Goodridge front and rear carboline brake lines,07 CBR1000RR front brake calipers,Vesrah race front brake pads,Targa tail kit,flush mount front signals,Cabon fiber led rear signals,Ohlins steering dampers,-1 front,Speedo Healer, Pilot Power tires,Gipro Tre and gold Sato's rearsets.
Daves Cycles is offline
post #3 of 22 Old 11-13-2008, 07:49 PM Thread Starter
Images: 7
I was doing it with the ignition on but engine off...per the instructions while on the rear stand. To change into the gear being learned during the learning process, I just move the rear tire a bit while clicking the gear shifter by hand. This is how the instructions were laid out that came with the G.I. Pro. But it also says that you can also do it with the engine as you described.
I will give that a try and see what happens....thanks.
post #4 of 22 Old 11-13-2008, 08:18 PM
No problem.
post #5 of 22 Old 11-13-2008, 08:22 PM
bluedevil's Avatar
you need to do it with the rear tire moving....try to get to a least 4000rpms for each gear.
bloo
bluedevil is offline
post #6 of 22 Old 11-13-2008, 08:47 PM
Postwhore with an 04
bcm0018's Avatar
Yeah mine has never worked perfectly but I feel the tre aspect of it on my butt dyno and the gear indicator works most of the time.
bcm0018 is offline
post #7 of 22 Old 11-13-2008, 09:46 PM
bloo
Hey blue I was just thinking about asking you that.I know you built your own.That's about how fast I been doing it at.I was just a little cautious to tell him first try to gas it,didn't want him flying off the stand.
So I guess the voltage the unit sees holds better with a little more RPM.I remember reading your post about how there isn't a big difference between gears
1st 3.0v
2nd 2.5v
3rd 2.0v
4th 1.5v
5th 1.1v
6th 0.7v if memory serves me right.
post #8 of 22 Old 11-13-2008, 09:52 PM
bluedevil's Avatar
1st 3.0v
2nd 2.5v
3rd 2.0v
4th 1.5v
5th 1.1v
correct, but the 5th and 6th are the hardest so it's better to program with the vibrations of a sensitive Gear Switch in RPMs as there is little error in Voltage.
post #9 of 22 Old 11-13-2008, 10:03 PM Thread Starter
Images: 7
Got out there and did it with the engine on while on the rear stand and that seems to have done the trick....thanks guys......
post #10 of 22 Old 11-13-2008, 10:12 PM
bluedevil's Avatar
1st 3.0v
2nd 2.5v
3rd 2.0v
4th 1.5v
5th 1.1v
and to add my Gear Indicator there is no programing and may be selling one soon....it will read the voltages and display the Gear just like a GiPro but has a little less delay as it does NO sampling it only registers what the Voltage IS at that time based on the table you showed.
help needed pc3 glosssilver General Motorcycle Discussions 0 05-19-2008 06:36 PM
Needed: 1killer1liter Wanted: Buy or Trade 0 03-07-2007 12:24 PM
Help needed kawboy69 Performance and Tech 12 07-04-2006 07:48 PM
PC3 Needed! VegasZX10R Vendors deals 3 09-16-2005 09:32 AM
