FYI: Transmission interchange between 1st and 2nd Gen - Kawasaki ZX-10R.net
post #1 of 1 Old 02-22-2011, 06:55 PM Thread Starter
clutch master's Avatar
Ok earlier I had the question about whether a 2nd gen transmission will work in the 1st Gen. Well here is the answer, the gear assemblies and gear shift shaft will work, but the drum, forks and fork shafts won't. If there are issues with the other parts of the transmission, you have to go gen specific. FYI
clutch master is offline
Wheels interchange??? bodymanruss518 ZX-9R Discussion 16 09-12-2019 08:15 PM
ZX10 - Z1000 top triple clamp interchange s4rhoolie The ZX-10R 8 03-27-2013 03:42 PM
Anyone here know what parts will interchange between the ZX-10 and ZX-11? Birdoprey ZX11 Discussion 0 09-11-2010 12:32 PM
10R & 14R swingarms interchange? cbolton69 Performance and Tech 3 04-05-2010 10:32 PM
Do 04-05 frames interchange with 06-07?? hibshman25 Performance and Tech 9 11-14-2007 09:36 AM
