Fuel tank Problems - Kawasaki ZX-10R.net
post #1 of 17 Old 06-09-2010, 02:06 AM Thread Starter
Fuel tank Problems
Hello, firstly I would like to thank you the welcome on this Zx forum, writting from Spain.
I just bough in USA a petrol tank for my zx10R 2006, and the model received is for the "USA california" zx10 model, that is lightly different from the "regular & European" tank.
The california has 2 more hoses: fuel return hose and fuel tank breather hose.
My simpley question is if someone could help and explain me if is possible to fit the California tank model on the regular model, and how to do that.
Do I need to close these 2 extra hoses and that's all?
Is it imposible to fit the california model on the regular model?
Thank you very much for your help, I'm lost... :-(
seti is offline
post #2 of 17 Old 06-10-2010, 11:13 PM
sextaafondo's Avatar
Hey man. welcome
You probably already know this but the -main-fuel hose to the common rail is the one coming out of the fuel pump.
If you have another hose pouring fuel out just block it in an absolutely secure way.
DO NOT plug the breather hose that goes to the fuel cap area or water may enter to the tank in the event that you wash the bike or ride in the rain.
sextaafondo is offline
post #3 of 17 Old 06-11-2010, 02:45 AM Thread Starter
Hi, thannks a lot for the help, I have the main hose going out for the fuel pump, another hose for the "extra fuel" goping out in the case is over fill, and the california model has 2 more hoses, one is Fuel return and the other Fuel tank breather.
So, if I close both (return and breather), will I have any proble of tank working?
seti is offline
post #4 of 17 Old 06-11-2010, 03:47 AM
Judge Dredd Mod
mr_honez's Avatar
Dont plug the breather hose. Just plug the second fitting (I used a rubber fuel plug secured with a clamp) and you'll be fine. If you plug both you may run into a problem where the fuel is pumped out and no air can get in causing the tank to deform.
BURNOUT.....
mr_honez is offline
post #5 of 17 Old 06-11-2010, 05:51 AM
By looking at the diagram I guess both extra vents may be left opened, as both go to the fuel cap area.
Just rooting a hose from both of them down to the lowers of the bike seems fine enough.
post #6 of 17 Old 06-11-2010, 06:08 AM Thread Starter
It is right that both goes to the top of the tank, but the breath(blue) goes to the fuel cap level and there is a hole on the top of the fuel cap narea to drop the over fuel, the other, the "fuel return"(red) goes to the top, but I don't see any hole on the tope, so probably the exit of the hose is between the internal layer of the fuekl tank and the area of the fuel cap.
In summary, I can plug a tube to the breather and bes used as a conduct for over fill.
But what happen with the "fuel return", I close it? or a plug a tube?
seti is offline
post #7 of 17 Old 06-11-2010, 08:42 AM
I'd plug a hose there too. Looks like that if you overfill the tank, the excess will be drained down that hose first, not the breather.
post #8 of 17 Old 06-11-2010, 04:43 PM
Guilty by association
CP10R's Avatar
yea you need the breather, but only the one fuel line
General "Mad Dog" Mattis
CP10R is offline
post #9 of 17 Old 06-14-2010, 01:53 AM Thread Starter
Done and working perfectly, thank you vey mcuh for your help. Great community
seti is offline
post #10 of 17 Old 12-10-2012, 04:53 AM
tasos's Avatar
Old post i know, but not clear enough...
I've just got a CA tank and want to know what to do:
On which color to connect a hose?
On which color to block?
Connect them together?
Tx!
tasos is offline
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 06:13 PM
04 Gas tank problems... CoochieCrook The ZX-10R 8 02-19-2010 10:30 PM
FS: 06/07 ZX10 - fuel tank/gas tank/fuel cell - Orange ninjaturtle Parts, Gear and Accessories 9 09-27-2009 05:23 PM
Gas tank problems Tenner The ZX-10R 4 06-23-2009 06:19 AM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
