fuel sending unit problem - Kawasaki ZX-10R.net
post #1 of 6 Old 06-13-2010, 01:53 PM Thread Starter
well, its not really a problem, but i removed the stock pump, sending unit, and tank base plate, and now i just want to know how to trick the comp into thinking i still have a full tank. it is only three wires to the pump assembly/ sending unit. any insight would be great. thanks
general01 is offline
post #2 of 6 Old 06-13-2010, 09:30 PM Thread Starter
come on guys, the flashing lights are driving me crazy.....
post #3 of 6 Old 06-21-2010, 02:01 PM Thread Starter
back to the top. some one must know the answere to this.......
post #4 of 6 Old 06-21-2010, 03:03 PM
themightymezzo's Avatar
What year bike is it?
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #5 of 6 Old 06-21-2010, 04:29 PM
Supercharged Mod
There is a power wire to run the pump, there is a signal wire to the fuel level sensor (which is simply an on/off switch), and there is a ground wire. Shop manual indicates which one does what, and whether switching it to ground indicates a "full" condition or an "empty" condition. Jumper the switch wire to ground and that's it.
But, why do you want to not know when you are about to run out of fuel?
GoFaster is offline
post #6 of 6 Old 06-21-2010, 08:39 PM Thread Starter
i hve tried jumping it to both 12v and ground and neither do the trick, so i wasnt sure if it was a resistence thing or something else, and its not that i dont want to know, but i put and external pump on the bike and now just have a plate with 2 6 an fittings in it(one feed and one return) thanks again guys, hopefully some one can shed some light on this for me
and its an 06
Bazzaz Kawasaki ZX10R 08-09 Z-Fi Fuel Control Unit WNTED Performance and Tech 6 03-21-2010 09:19 PM
zx12r Fuel Problem travis lutter General Motorcycle Discussions 8 11-04-2009 09:28 PM
Possible to change lock unit on the Fuel Cap? NYC_ZX10 The ZX-10R 2 05-11-2008 04:35 PM
Fuel in Oil Problem back again. one_half_wuff The ZX-10R 4 08-18-2007 12:36 AM
fuel pump problem? carlzx10 Performance and Tech 13 01-27-2007 05:25 PM
