Gen 3: 2008-2010 Fuel pump replacement - Kawasaki ZX-10R.net
post #1 of 15 Old 07-08-2012, 03:53 PM Thread Starter
oldkamikaze's Avatar
I want to put a Walbro fuel pump in my 08. I got a Walbro GSS342 21109-1 off ebay. Think I got the wrong one, won't fit. does anyone know the right pump. Stock pump on left. Click image for larger version
Akra Full system -K&N A/F - velocity stacks,Dyno-Tune Nitrous, 20 oz bottles with Purge,pressure gauge, Dynojet P/C V,Dynojet ing.Mod.GuhlMotors,Reflashed ECU, Block off plates, EK 520 ZZZ chain,Vortex and Supersprox sprocket,Roaring Toyz 5 position lowering link, Driven Axle block,Shogun frame sliders, R&G Racing case sliders,Vortex clip-ons,ASV short levers, PMR Killswitch,Galfer SS brake lines, EBC Extreme pads ,Galfer wave roto, Vortex rearset, Ohlins race steering damper.and More 250 HP
oldkamikaze is offline
post #2 of 15 Old 07-08-2012, 03:59 PM
Tee's Kawa55's Avatar
here you go man
http://www.bikebandit.com/houseofmot...8912#sch582403
DDM Tuning HID lights| Sportech Windscreen| ASV shorty levers| Driven D3 grips| Evotech 1/4 turn gas cap| LSL sliders| Woodcraft case covers| PCV with custom map| BMC race filter| secondaries removed| EK 525 red chain| Vortex rearsets| M4 Slayer exhaust| PSR chain adjusters| Speigler brake lines| custom front and rear seat| Pro bolt aluminum bolt kit| Hellrazor servo eliminator
Tee's Kawa55 is offline
post #3 of 15 Old 07-08-2012, 05:25 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
https://www.zx-10r.net/forum/showthre...ht=Walbro+pump
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #4 of 15 Old 07-09-2012, 10:45 AM
plasticbaby's Avatar
LOL,kawi claimed that the fuel pump of gen3 was non detachable and cannot clean the fuel filter.
Was it difficult to detachable ? Did you see the fuel filter?
Would love to see if you can shot some photos.
plasticbaby is offline
post #5 of 15 Old 07-09-2012, 11:36 AM Thread Starter
I didn't have any problem taking it apart. Filter came right out after I got the pump out. Iím just trying to find out what Walbro pump I need to get. I'll try to get photos to show you.
post #6 of 15 Old 07-09-2012, 12:48 PM
you are the first one mod gen3 pump in this forum .good luck with your mod £¶ let us know the results.thank you very much !
post #7 of 15 Old 07-09-2012, 07:51 PM Thread Starter
I marked all wires and cases
#1 Take out two screws at top and remove bracket. Take wires off.
#2 Pry the top and bottom case apart evenly using two screwdrivers.
slide plastic case off of metal brackets.
#3 Take small cover over wires off . Take wires off top of motor. Grab motor terminal with pliers and pull up on motor while wiggling back and forth
#4 The filter comes out the opposite end the pump out.
When trying to put pump back together I would use silicone on the rubber O-rings
post #8 of 15 Old 07-10-2012, 09:34 PM
It does help!reputation sent!
post #9 of 15 Old 07-15-2012, 07:49 PM Thread Starter
Gen:3 Walbro 255 pump conversion
Here it is Gen:3 Walbro 255 conversion with stock pressure relief valve. Now when I get the motor back in I will let you know how it works,
ID:	163598   Click image for larger version
ID:	163599   Click image for larger version
post #10 of 15 Old 07-20-2012, 12:13 AM
Definitely the best gen3 pump mod.Nice cut of the fuel pump blocker(prevent the drop out of the pump), no reason it does not work
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 06:13 PM
fuel injector or fuel pump??? Dnicezx10r The ZX-10R 2 12-13-2011 07:16 AM
Fuel Injectors and Fuel Pump Crazi Parts, Gear and Accessories 0 10-21-2009 07:42 PM
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 10:39 AM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
