Gen 1: 2004-2005 Fuel pump not working ?? help - Kawasaki ZX-10R.net
post #1 of 34 Old 05-18-2011, 06:03 PM Thread Starter
Z1R
Any advice welcome. 2004 ZX10r Ignition on, bike turns over, power to coils, no power from white/red stripe wire that comes from fuel pump relay. Fuel pump relay will turn on fuel pump if brown/yellow stripe wire that comes from ecu, pin #58 is grounded. Have changed out the ecu with a different one with the same results. Any ideas on what can stop the ecu from
grounding the fuel pump relay.
Z1R is offline
post #2 of 34 Old 05-18-2011, 06:57 PM
09zx10miami's Avatar
Add your own relay to the fuel pump and call it a day...
****Giiiiiiiiittttttuuuurrrdooonnneee****
09zx10miami is offline
post #3 of 34 Old 05-18-2011, 07:16 PM
ducatiryder89's Avatar
Images: 21
Could be faulty clutch or kickstand switch. Have you checked those?
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #4 of 34 Old 05-18-2011, 07:25 PM Thread Starter
Z1R
The fuel pump was not on all the time as it would be if I ran it through a remote relay.
Both clutch and side stand switches work as they should. Thanks
Z1R is offline
post #5 of 34 Old 05-18-2011, 07:31 PM
Images: 21
I'm guessing you still have key and ignition correct? That could also be culprit. I believe the ECU verifies three different sources to ground fuel pump relay. Clutch, sidestand, and ignition switch. Kinda odd that ECU won't ground relay with all three working properly. Especially on a second ECU. Are you checking grounds with kickstand up and clutch switch engaged?
post #6 of 34 Old 05-18-2011, 07:39 PM Thread Starter
Z1R
Yes have key and ignition and yes to side stand and clutch.
Z1R is offline
post #7 of 34 Old 05-19-2011, 09:01 PM
Images: 21
Weird one possibility of a loose pin or a bad contact somewhere?
post #8 of 34 Old 05-20-2011, 10:35 AM Thread Starter
Z1R
Thanks all for help Turned out it was the grey wire from the ignition switch to ecu that sends a reduced voltage when ign turned on. No voltage no fuel pump.
Z1R is offline
post #9 of 34 Old 07-31-2011, 12:47 PM
Deagol's Avatar
Did you find out why ?
I'm having problem with the fuel pump too !
Sometimes it just won't start up, then I push the cables under the seat om the left side and it goes back on , mostly when It's warm....
Skort circuit mabybe ?
Did I say I've got a white one? Erhm I've got a white one but still, kind of miss my green one!
Deagol is offline
post #10 of 34 Old 08-01-2011, 02:10 AM
gilos's Avatar
does it happen when you ride?
cause it happens to me where the motor just shuts down..
when i turn the key OFF and ON again..i cannot hear the pump noise..and it wont fire up.
how do you check this? what is your voltage reading? How do you fix it?
Thanks.
gilos is offline
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 06:13 PM
Fuel Injectors and Fuel Pump Crazi Parts, Gear and Accessories 0 10-21-2009 07:42 PM
Low fuel light not working. otto The ZX-10R 7 06-07-2009 07:57 PM
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 10:39 AM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
