Fuel pump gone...inline pump and regulator? - Kawasaki ZX-10R.net
post #1 of 16 Old 05-03-2008, 02:12 AM Thread Starter
bugman53's Avatar
05 zx10 with 6700 miles. Iím pretty sure my fuel pump has taken the big plunge. I have not had time to tear it apart b\c of working on customers bikes ( is sad the mechanics bike is always broke) The bike had been running inconsistently for some time now some days it was stronger than others. Wednesday on a ride it started surging under hard load. so i think the pump had been on its last let for some time now. now it will die if I whack it to WOT.
I really donít wont to go back to the stock pump setup. i would like to do a inline pump and regulator. Any one got any suggestion on with pump to go with. The last inline i did on my jeep was LOUD!!! is there any quiet inline pumps? Also regulators.. areomotive?
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #2 of 16 Old 05-03-2008, 02:16 AM
bluedevil's Avatar
Originally Posted by bugman53 View Post
05 zx10 with 6700 miles. Iím pretty sure my fuel pump has taken the big plunge. I have not had time to tear it apart bc of working on customers bikes ( is sad the mechanics bike is always broke) The bike had been running inconsistently for some time now some days it was stronger than others. Wednesday on a ride it started surging under hard load. so i think the pump had been on its last let for some time now. now it will die if I whack it to WOT.
Not going to search for you but FAF on this site and a few others have done extensive research for aftermarket pumps.....do the search it's already been covered with the information your seeking.
bloo
bluedevil is offline
post #3 of 16 Old 05-06-2008, 05:56 PM Thread Starter
bugman53's Avatar
I looked through all the post and all i can find is the walbro to replace the intank pump.
I plan to take the pump out of the tank and make a plate with some 6an or 8an fittings and run a inline pump and regulator.
All the pumps i have found are for 500+hp and are pretty noisy. Any suggestions as to what woud be a good pump for the my application? ill spend up to $500 on the setup.
I have heard of some systems on busas like this one but i have not seen any info or specs on them.
Greeensboro NC
bugman53 is offline
post #4 of 16 Old 05-06-2008, 06:11 PM
Email me your ship-to address and I will send you a complete low-mileage unit for the shipping cost alone. It may not be what you are looking for - but you can ride your bike without much worry.
John
San Jose, California
cbxfixer is offline
post #5 of 16 Old 05-07-2008, 05:46 AM
FAF
Rent this space
There are a zillion pumps you can use, my second bike (still in progress) has a walbro 255 external pump, bosch filter and aeromotive regulator with return system , running 60lbs pressure.
Vince10R has an external Walbro too.
The stock fuel pump will fuck up your day in a heartbeat, it is Mitsushiti dung.
FAF is offline
post #6 of 16 Old 05-07-2008, 08:32 AM
Vince10R's Avatar
I run the walbro 255 inline on mine, It is no where near as loud as the walbro intank pump I had in it, but still louder than stock. Finding room for it is the hard part.
Vince10R is offline
post #7 of 16 Old 05-07-2008, 08:56 AM
FAF
Rent this space
I got mine in the rear subframe next to the fuel filter.
FAF is offline
post #8 of 16 Old 05-13-2008, 11:20 AM Thread Starter
bugman53's Avatar
Does anyone know the name for the quickconnects on the fuel rail? I cant find them. I will probaly just weld me a An adaptor on it.
Greeensboro NC
bugman53 is offline
post #9 of 16 Old 05-13-2008, 12:44 PM
Vince10R's Avatar
I just tig welded a steel 6an fitting to the inlet for the fuel rail.
Vince10R is offline
post #10 of 16 Old 05-13-2008, 10:05 PM
redline659's Avatar
Spend a lil more money and get a Bosch. Bosch is OEM on a few vehicles and OEM stuff is ALWAYS better
redline659 is offline
2004 ZX10R Water Pump/Oil Pump leak notjeep The ZX-10R 4 09-17-2013 10:07 PM
FUEL PUMP for 04-05 zx-10R kneedraggin Parts, Gear and Accessories 1 05-04-2007 01:26 PM
bad fuel pump sweetride10r Performance and Tech 8 03-26-2007 02:25 PM
fuel pump not on reckless1 ZX-6R & ZX-6RR Archives 0 06-08-2006 05:42 PM
WTB: '04 ZX-10R fuel pump bikerscum Wanted: Buy or Trade 0 04-04-2005 08:01 PM
