Gen 1: 2004-2005 Fuel Pump Gasket - Kawasaki ZX-10R.net
post #1 of 7 Old 04-25-2012, 11:41 AM Thread Starter
Eric_The_Jew's Avatar
Fuel Pump Gasket
Gonna have a go at cleaning my fuel pump screen (filter). Looking at the service manual, it says to replace the gasket where the pump mates to the tank. Microfiche describes the gasket as an o-ring, which is usually re-useable. Just curious if people actually replace this or is it one of those overkill factory recommendations like replacing the crush washer on your drain plug every time?
I'm usually meticulous about doing things by the book, but frankly I wanna go ride after this and don't feel like waiting a week for RonAyers to ship one.
Eric_The_Jew is offline
post #2 of 7 Old 04-25-2012, 12:07 PM
Slow Poke
bgmagma10's Avatar
I've reused mine a couple times. It was even pinched a little bit when I pulled it out, but re used it and its been working for prob 3 years now..
bgmagma10 is offline
post #3 of 7 Old 04-25-2012, 12:15 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
I replaced mine just in case my original wanted too act up.. i have a spare now..
U should b fine reusing it ..
06blackpearl is offline
post #4 of 7 Old 04-25-2012, 09:31 PM Thread Starter
Thanks guys... Just finished buttoning her up. Job went smooth...fuel pump had crap all inside it so I gave it and the screen a thorough cleaning. We'll see if it leaks tomorrow
post #5 of 7 Old 09-29-2012, 02:33 AM
what did you do to clean it out i need to do mine too
doppler8000 is offline
post #6 of 7 Old 09-29-2012, 05:52 AM Thread Starter
I think I used kerosene and a toothbrush, but I think you could use just about any solvent as long as it isn't too harsh.
post #7 of 7 Old 09-29-2012, 10:56 AM
It is made from Viton Rubber so it is chemical resistant to almost everything but acid. Also apply a little oil or vasoline to it. it will last longer
Gixx1300R is offline
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 07:13 PM
Gen 1: Fuel pump gasket Palehorse The ZX-10R 2 02-29-2012 12:44 PM
What Head Gasket to use and still run pump gas? kawsquid23 Performance and Tech 6 08-13-2010 10:06 PM
Fuel pump gasket pan Wanted: Buy or Trade 4 07-11-2008 03:27 PM
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 11:39 AM
