Fuel Pump? - Kawasaki ZX-10R.net
 4Likes
  • 1 Post By Neonmarine
  • 1 Post By realpsi
  • 2 Post By realpsi
post #1 of 9 Old 05-21-2019, 06:16 PM Thread Starter
Fuel Pump?
So I just ran my 2018 ZX10R off track this weekend. I laid the bike down gently in the sand and broke nothing except my ego.
The bike started back up and I ran two more laps before being summoned to pit back in. At the end of the 2nd lap right before I pit in the bike made a loud clicking noise that I think was my fuel pump running dry. I shut the bike off immediately and coasted in. I never did get the bike to restart. When the key is turned on with switch in OFF position then put switch in ON position I do not hear the fuel pump priming. Bike will crank for a quick second and thats it. No fuel.
I haven't unloaded my trailer yet but is this a fuel pump or could it be a short in the switch itself? Would a crash cause it to burn the pump up if ran empty?
wheelz96 is offline
post #2 of 9 Old 05-21-2019, 10:12 PM
I don't have one of the current model ZX-10R's, but would the tip over switch be affecting the bikes inability to start? This could be something to look at to make sure it's not causing issues.
RoninZX10R is offline
post #3 of 9 Old 05-22-2019, 05:36 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
Yeah, my pump went out on the dyno last time at KWS. I'd see if it's something electrical first but don't be surprised if its the pump. Got a Busa pump in it now, not sure if it was a drop in replacement but Mike at KWS knows his stuff. Might not hurt to give them a call or swing by if you're in the Charleston area.
wheelz96 likes this.
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #4 of 9 Old 05-22-2019, 07:41 AM
Your problem reads like an interlock/electrical issue and not a fuel pump problem. Gen 4 here, but when my fuel pump doesn't even attempt to prime with key on - it is kill switch, kickstand down in gear, tip over, in gear clutch not in.
Neonmarine likes this.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #5 of 9 Old 05-22-2019, 11:33 AM Thread Starter
Tip over was first thing I checked at track and tested with volt meter all good. I have a jumper plug for kickstand(removed) switch and that tested OK. I will take actual switch apart first then follow wire back to pump. Strange it happened after running two laps before I heard the pump run dry.
wheelz96 is offline
post #6 of 9 Old 05-22-2019, 02:52 PM
Neonmarine's Avatar
Are you sure it was the pump sound you heard? Did you not have enough fuel?
post #7 of 9 Old 05-22-2019, 03:13 PM
You should be able to get to the plug for the fuel pump and check voltage there. Also, I bet there is a fuse for the pump.
wheelz96 and Laczi like this.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #8 of 9 Old 05-22-2019, 06:17 PM Thread Starter
Well I suppose I'm not positive but a fuel pump that runs dry has a very distinct sound and considering it doesn't work or prime anymore I am fairly certain that this is whats going on. It's either the circuit to the fuel pump or the pump itself. I will take it apart one day this week and find out.
P.S. Tank was almost full. It was only lap 2 :(
wheelz96 is offline
post #9 of 9 Old 05-22-2019, 11:15 PM
michael4012's Avatar
Is the pump getting power? Have you put a meter on it?
michael4012 is offline
fuel injector or fuel pump??? Dnicezx10r The ZX-10R 2 12-13-2011 07:16 AM
Fuel Injectors and Fuel Pump Crazi Parts, Gear and Accessories 0 10-21-2009 07:42 PM
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 8 02-17-2009 12:04 AM
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 10:39 AM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
