Gen 1: 2004-2005 Fuel pump??????? - Kawasaki ZX-10R.net
post #1 of 17 Old 09-04-2012, 07:18 AM Thread Starter
tone.r's Avatar
Fuel pump???????
WELL this just started yesterday i was about to go for a ride BUT the fuel pump would'nt come on:dontknow, this just started out of the blue does anybody have ant idea what the hell could be going on?
I did check the plug
I checked the fuse box
I made sure the battery was 100% chargered up
I put my spare pump on the bike still nothing
HELP
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #2 of 17 Old 09-04-2012, 08:31 AM
ZxTennessee's Avatar
Take off your tank and fuel pump and turn on key with run switch off, get your multi meter ready then flip the run switch to on and test the wires going away from the tank and pump to make sure they have power, if so then you can plug your pump in and put your ear right up to it and listen for noise, or get 2 wires and run from batt to fuel pump and see if it runs the pump. Then you will know if it is the pump or not
ps make sure there is gas in the tank
ZxTennessee is offline
post #3 of 17 Old 09-04-2012, 12:32 PM
badassjake's Avatar
the relay box may have crapped out on you....the little black box with the 2 connectors on the top of the ECU.
badassjake is offline
post #4 of 17 Old 09-04-2012, 12:44 PM
PatrickG's Avatar
Images: 15
Tony check the connector on the main wiring harness behind the left side cover. It's taped up with the harness, mine did the same thing. I moved the wiring around and the fuel pump kicked on immediately. It is a 10-12 pin connector and it corrods and burns itself up.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #5 of 17 Old 09-04-2012, 01:43 PM
Does not drive into smoke
El Zilcho's Avatar
Kill switch?
El Zilcho is offline
post #6 of 17 Old 09-04-2012, 04:31 PM
Austinjval's Avatar
Same problem with my bike, I'll be watching this thread as well. Here's a link to mine that has a lot of suggestions. Good luck and keep me posted if you figure it out.
https://www.zx-10r.net/forum/showthread.php?t=119049
Austinjval is offline
post #7 of 17 Old 09-04-2012, 04:44 PM Thread Starter
tone.r's Avatar
thx i seen yours yesterday i was having something like what your having going on 2 months ago it was my battery plus connector that goes to the relay on the right side
Tone.R {checkmate}
tone.r is offline
post #8 of 17 Old 09-04-2012, 04:46 PM Thread Starter
tone.r's Avatar
thx guys i will check when i get home from work today, its crazy because i was just riding the bike the day before
Tone.R {checkmate}
tone.r is offline
post #9 of 17 Old 09-04-2012, 05:47 PM
badassjake's Avatar
i did have the fuel circut in the ECU shit the bed too....it was self induced, everythign worked perfect, except the fuel pump priming........replaced the ECU and all went back to normal.
post #10 of 17 Old 09-04-2012, 09:37 PM Thread Starter
tone.r's Avatar
might sound crazy but i think it was not having my front sprocket cover on, I put my cover back on now my pump is working again crazy, it must be a ground im thinking
Tone.R {checkmate}
tone.r is offline
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 06:13 PM
fuel injector or fuel pump??? Dnicezx10r The ZX-10R 2 12-13-2011 07:16 AM
Fuel Injectors and Fuel Pump Crazi Parts, Gear and Accessories 0 10-21-2009 07:42 PM
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 10:39 AM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
