Fuel Pressure on Gen:3 - Kawasaki ZX-10R.net
post #1 of 2 Old 07-06-2012, 05:47 PM Thread Starter
oldkamikaze's Avatar
Hi Bill here I have a few questions. 1. Can anyone tell me what the stock fuel pressure on a Gen:3 is 2. What is the best place to hook up a fuel pressure gauge to be mounted on bike. 3. suggestions on what pressure to run on a motor with 235 hp using nitrous. Thanks for any help.
Akra Full system -K&N A/F - velocity stacks,Dyno-Tune Nitrous, 20 oz bottles with Purge,pressure gauge, Dynojet P/C V,Dynojet ing.Mod.GuhlMotors,Reflashed ECU, Block off plates, EK 520 ZZZ chain,Vortex and Supersprox sprocket,Roaring Toyz 5 position lowering link, Driven Axle block,Shogun frame sliders, R&G Racing case sliders,Vortex clip-ons,ASV short levers, PMR Killswitch,Galfer SS brake lines, EBC Extreme pads ,Galfer wave roto, Vortex rearset, Ohlins race steering damper.and More 250 HP
oldkamikaze is offline
post #2 of 2 Old 07-07-2012, 12:44 AM
thundercoupe9's Avatar
stock fuel pressure should be in the 43 psi range. I'd stick to that pressure unless your injectors are getting maxed out, which they shouldn't since you have 8 of them.
thundercoupe9 is offline
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 06:13 PM
fuel injector or fuel pump??? Dnicezx10r The ZX-10R 2 12-13-2011 07:16 AM
? about fuel tank pressure Only_One_R1 ZX-14 Discussion 1 03-06-2011 08:20 PM
07 zx10 stock fuel pressure? brandon1566 Performance and Tech 1 10-15-2009 06:52 PM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
