Gen 4: 2011-2015 Fuel pressure/delivery issue? - Kawasaki ZX-10R.net
post #1 of 2 Old 06-20-2018, 07:54 PM Thread Starter
arc
arc's Avatar
Question Fuel pressure/delivery issue?
2014 ZX-10R, AU model, 110,000 kms, Akra slip on + link pipe, Annatori quick shifter.
Symptom: wide band sensor goes very high (17-21 AFR) on very mild acceleration, worse at higher RPMS, less bad going up into higher gears at static RPM. Full roll and and the bike will stall (unconfirmed). Was worse when the tank showed the reserve light, now consistently bad. Initially happened only at full roll on, been getting worse over the last 5,000 kms or so, now happens even with very slight throttle.
Tried so far: new fuel pump (aftermarket internal), new fuel filter (was very dirty) and new fuel pressure regulator. Tank cleaned, injector cleaner used multiple times. New spark plugs. No fuel line leaks. Fuel rail seems OK. Applied stock fuel map (using Woolich Racing reflash). Happens in Low, Medium and Full power modes. Doesn't appear to happen in neutral (no load though). Air filter OK, no leaks in air box. Fuel pump primes OK when ignition switched on. Woolich log box showing throttle position sensor opening up. Seems to happen in both IAP and TPS maps (it only takes a very slight roll on now for the issue to show).
Any ideas? Bike unusable like this :(
Thanks for your help,
A.
Tomorrow, when I wake, or think I do, what shall I say of today?
Samuel Beckett, Waiting for Godot
arc is offline
post #2 of 2 Old 06-20-2018, 07:58 PM
thundercoupe9's Avatar
Check fuel pressure while riding with a gauge.
thundercoupe9 is offline
Tags
fuel power loss afr
Gen 1: Low fuel pressure ninja10kid The ZX-10R 12 12-11-2013 07:48 AM
Oil pressure issue dabl131 The ZX-10R 9 05-28-2012 07:01 PM
? about fuel tank pressure Only_One_R1 ZX-14 Discussion 1 03-06-2011 08:20 PM
Problem tuning my bike, no top end fuel delivery. customspeed The ZX-10R 5 09-13-2010 08:57 PM
Final word on 06' Fuel Delivery Auron The ZX-10R 13 04-30-2006 01:00 AM
