Front Wheel Removal - Kawasaki ZX-10R.net
post #1 of 14 Old 01-01-2006, 11:27 PM Thread Starter
05Ti10's Avatar
Front Wheel Removal
I am going to be removing my front wheel soon to get the new tire mounted up. I have searched a bit and here is what I came up with:
1. Put bike on rear stand and place my floor jack under the jack point on the header. This will get wheels off the ground. I did this before to raise the fork tubes a bit. Worked fine.
2. Remove the brake calipers so the wheel can fit through and be removed. (is this really needed or can I just remove one side???)
3. Loosen the pinch bolts on the left side first and unscrew the allen nut using the 14MM alllen key in the tool kit being careful since it is soft aluminum.
4. Loosen pinch bolts on the right side to remove the axle. At this point the wheel should be able to be removed.
Any issues with the above? Anyone have the torque specs handy for the pinch bolts, caliper bolts, and axle nut? This will be first time removing the front and the above is the best I could come up with from my searches. Any advice is appreciated.....thank ya.
Steve
05Ti10 is offline
post #2 of 14 Old 01-01-2006, 11:43 PM
Big Daddy's Avatar
Images: 38
the procedure sounds right.
Tq specs
axle pinch bolts 14.5ft-lb
axle nut 81ft-lb
caliper bolts 25ft-lb
Big Daddy is offline
post #3 of 14 Old 01-02-2006, 01:09 AM Thread Starter
05Ti10's Avatar
Thanks BD, much appreciated.
Steve
05Ti10 is offline
post #4 of 14 Old 01-02-2006, 10:44 AM
zeta xray's Avatar
Yup, remove both calipers. You got it perfect.
Don't confuse me with facts, my mind is already made up.
zeta xray is offline
post #5 of 14 Old 01-02-2006, 10:49 AM
jayrc30 is offline
post #6 of 14 Old 01-02-2006, 10:58 AM
Caliper mounting bolts ..................25 ft/lbs
Front axle clamp bolts...................14.5 ft/lbs torque them a couple of times
Front axle nut..............................81 ft/lbs
I don't torque the front axle more than finger tight because it tends to squeeze the fork legs together and causes more stiction.
swjohnsey is offline
post #7 of 14 Old 01-02-2006, 11:10 AM
Big Daddy's Avatar
Images: 38
incase you didn't read the other posts everything is already listed.
If your forks are squeezing that much theres a problem needing attention. Both of my spacers make contact with the inner fork bottoms when installing the front wheel so theres 20thou (guess) at best they squeeze/compress when torqued down.
post #8 of 14 Old 01-02-2006, 11:26 AM
Sorry I offended you by reposting some information. If you don't think it will improve the performance of your forks don't do it.
post #9 of 14 Old 01-02-2006, 11:30 AM
Big Daddy's Avatar
Images: 38
no offense taken it just wasn't necessary, and no finger tight will not cut it.
post #10 of 14 Old 01-02-2006, 11:58 AM
zeta xray's Avatar
I tighten the axle nut as recommended, however, I do not tighten the pinch bolts until I have pumped the forks up and down a few times to make sure there is no side loading due to the axle being off center or some other issue. Then I tighten the pinch bolts. I would think that leaving the axle nut finger tight could allow the forks to twist more easily. Resulting in a less stabile front end.
Updated Front Wheel for Sale!! madkaw Parts, Gear and Accessories 3 12-07-2005 09:19 PM
need help whith front wheel? mustv8 The ZX-10R 25 09-17-2005 01:58 AM
removing the front wheel Older Guy Performance and Tech 2 05-22-2005 09:33 PM
2004 2005 R1 10R D218 Tires and R1 front wheel INR1 Parts, Gear and Accessories 6 02-10-2005 09:53 PM
Warning About BST Carbon Fiber Wheels........ SP8 The ZX-10R 20 01-18-2005 08:28 AM
